Front left malfunction - but OBD doesnt show any errors
Old Oct 14, 2024 | 11:50 AM
Sem1989's Avatar
2016 GLA Manual Diesel 2.1
Hello,
I have a C200 CGI 2011.
I needed to change the buttons on the steering wheel, so I took it off. While the steering wheel was off, I connected the battery back (by mistake).
So now I have a "front left malfunction consult workshop" error displaying, I have 2 OBD devices and none of them show any error codes.
I tried to clear errors but it still presists.
Any advice?
Thanks!
Old Oct 14, 2024 | 03:44 PM
TimC300's Avatar
Front left what? It just says front left malfunction?
I would have guessed connecting the battery back while the steering wheel is off would cause an air bag fault. Are any warnings on the dash on, abs?
What obd tool are you using, a Mercedes specific one?
Maybe post a photo of what it shows.
Old Oct 15, 2024 | 03:04 AM
streborx's Avatar
Top Answer: 1
G550
OBD scanners have different levels of scanning depth and coverage. If you have an instrument panel error displayed, but your scanner reads no codes, it's likely that your scanner is inadequate.
Old Oct 15, 2024 | 05:41 PM
Sem1989's Avatar
Hey, Apologies for the missing info.
The dashboard says "Front left malfunction consult workshop," and the airbag light (red) is on.
You are probably right about inadequate scanner, I have ordered another one and tomorrow morning I will walk to a garage near here and ask if they can reset the light.
The thing is, I have imported the car to Europe and it's waiting for tomorrow to pass the car inspection so I have to fix the light by noon tomorrow (waited for the inspection for 2 months).
Old Oct 15, 2024 | 06:33 PM
JettaRed's Avatar
Veteran: Army
Crap! I wrote something but apparently forgot to post it. Watch this video. It's for a W203, but the W204 has the same problem. I had it happen to me. Once fixed, a good Mercedes scanner (e.g., XENTRY, LAUNCH Creader Elite BENZ, etc.) can clear the code and light.
Old Oct 15, 2024 | 06:37 PM
JettaRed's Avatar
Veteran: Army
Old Oct 15, 2024 | 09:37 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Got this from a recommendation here. If what you ordered is similar, then it’s likely to work.
https://a.co/d/bI2x8bC
Old Oct 15, 2024 | 09:40 PM
cvx5832's Avatar
325Ci, 325Cic, C300
https://youtu.be/ZYsMYki8hUw?si=8JpZvq2_LfZ9HiAA
Same. Driver side malfunction at 12 years and 154k miles. Passenger side malfunction 3 years later at 217k miles.
Old Oct 16, 2024 | 03:32 AM
BenzNinja's Avatar
Former Vendor
These faults sometimes only show up in developer
no way you see them with aftermarket.
I can fix this easy with proper diagnostics
but try something. put your car back together. then battery off 30 min
and back. eventually after drive it a mile lock the car keys away and see if fixed
good luck
Old Oct 16, 2024 | 08:15 AM
Sem1989's Avatar
Hey, just an update, a friend with a good scanner came and did a reset, as I thought it was the steering wheel airbag, now everything is fine and the car has passed it MOT
Old Oct 16, 2024 | 10:38 AM
JettaRed's Avatar
Veteran: Army
Good to hear.
