ESL
Old Mar 12, 2025 | 06:25 PM
KeptK's Avatar
Meredes C230
ESL
I have a question and I need answers quickly please!!
I had the same thing that a lot of my other W204 drivers have had:: my ESL won’t unlock. I sent the ignition switch and key out to California and had an emulator made. Unfortunately I live in a small town and I don’t have anyone that can service it. So, I had my car towed to the MB dealership and they want to charge me $1,032 to remove the ESL and 1,906 to replace the ESL, but I already have the emulator. What would you guys do??
Old Mar 13, 2025 | 12:58 AM
WestonMerc's Avatar
2015 C250 Coupe M271.860
Hmm. I’m guessing the ESL died in locked position. I’ve heard with some combination of making sure you have a fully charged battery and literally giving the steering column a good whack you can free the lock upon ignition startup. Then you can swap in the emulator much more easily than pulling out the whole steering column.
I guess another idea if you cant DIY anything is have your car towed to a shop or locksmith that can do the work. Or find a mobile mechanic and convince them to travel where you are, maybe pad there fee for the travel
Just throwing out ideas. I live a big metro again so I would always have access to nearby shops.
Old Mar 13, 2025 | 02:18 AM
KeptK's Avatar
Meredes C230
Yea, thanks though!! I was really looking for thoughts as to whether I should pay $1,023 to have them take the ESL out (since I already have an emulator) or pay the $1,902.00 and just have them replace the ESL, even though I already have the emulator. The car is already at the Mercedes Benz shop.
Old Mar 13, 2025 | 02:35 AM
KeptK's Avatar
Meredes C230
Yea, thanks though! The car is at the Mercedes Benz dealership. I guess what I’m really looking for is thoughts as to whether I should have them take out the ESL, pay the $1,023 and then the put the emulator in, or whether I should go ahead and pay the $1,900 something to just have them replace the ESL. The car is an 08 C350, and has 122,000 miles on it. I think I should just do the emulator but I wanted to get you guys thoughts on it first. Thanks and keep posting!!
Old Mar 13, 2025 | 07:12 AM
trigital's Avatar
W213 All-terrain
A 12$ electric motor would do the trick.... dismantling it's the hard part, but YouTube is full of that
Old Mar 13, 2025 | 10:34 AM
Demvang's Avatar
2011 C300 4Matic Sport
As WestonMerc said, try to give ESL a good whack, hopefully it would unlock before it completely dies and then drive home doing an emulator swap. This reminds me of the starter on my Isuzu Amigo, have someone crank while I tap on the starter
Old Mar 13, 2025 | 03:09 PM
KeptK's Avatar
Meredes C230
I would if I had known before having it towed to the Mercedes Benz dealership. O well, thanks anyway!!
Old Mar 13, 2025 | 06:35 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Since you’re not looking for an adventure (removing a locked ESL is very time consuming and difficult) my suggestion is to have the dealer remove the ESL. But will they also install the emulator? I’m not sure that the dealer would do that because that’s an antitheft device.
https://mbworld.org/forums/c-class-w...ts-pics-2.html
Scroll to the video. In real time that is more than 1 hour’s work.
Old Mar 13, 2025 | 07:08 PM
KeptK's Avatar
Meredes C230
Thanks a lot!! I just got off the phone with the Service Advisor at MB dealership and I advised them to go ahead and remove the ESL completely. Now, do you think I would have a problem from the dealership with installing the emulator since it has to be a Mercedes Benz part or should I just go ahead and call a tow truck when I get there? The emulator is only one cord. Thanks again!
Old Mar 13, 2025 | 10:06 PM
KeptK's Avatar
Meredes C230
I just said I wish I knew about this site earlier, because I would’ve tried that. Thanks though!! 🙂
Old Mar 14, 2025 | 12:03 PM
Odd Piggy's Avatar
If the dealer will install a 3rd party part I would say go ahead and let them do it. The car is already apart and you will be back on the road. Whether they will do it or whether they will refuse and insist that you use the new ESL is the big question.
Old Mar 14, 2025 | 12:48 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
If they won't install your emulator then just do that part yourself.
There is nothing to installing the emulator as all you really have to do is plug it in then shove it somewhere under the dash. It does not need to go back into the spot where the ESL came from since it don't do anything except make up limits to say you're steering is unlocked.
Piece of cake. And then you could drive it home.
Old Mar 14, 2025 | 03:58 PM
Odd Piggy's Avatar
Maybe, maybe not.
Don’t know the details of the work order, however, if “remove the ESL” doesn’t include “reinstall the steering column” that’s not going to work.
Old Mar 20, 2025 | 11:53 PM
KeptK's Avatar
Meredes C230
Great news!!! I finally got my ESL out at the Mercedes Benz dealership and I put the emulator in. Car started right up. They wanted to charge me over 1,900.00 to replace the ESL, but I said nah, I have the emulator so I just had them remove the ESL. It was plug and play with a cord, and my car started, and I couldn’t be happier. $1,020.00 is all I had to pay. If I knew someone in my area it would have been cheaper, but I live in a small town. Thanks to all who responded!!
Old Mar 21, 2025 | 02:13 AM
RobertR728's Avatar
Very nice. I told you it was pretty easy to put in. Glad you got it sorted.
Old Mar 22, 2025 | 05:36 PM
TimC300's Avatar
I came across something about the ESL in a bulletin. Im not sure if it means Mercedes will cover the costs to replace it or not.
