Bonnet open warning
Old Mar 24, 2025 | 09:18 PM
Dave Hart's Avatar
2012 c200cdi. 2008 Vito
Bonnet open warning
Bonnet open warning.
Hi I have replaced both bonnet closing sensors in my 2012 c200 and still get a bonnet open warning constantly. Any suggestions?
Old Mar 24, 2025 | 10:22 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Mar 24, 2025 | 10:39 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
You need to supply us info.
Car info including the VIN and someone might be able to help you then.
Old Mar 24, 2025 | 11:33 PM
Dave Hart's Avatar
Hi Thanks for your reply. Vehicle details are; 2012, C200CDI sedan VIN WDD2040012A689629
Old Mar 25, 2025 | 12:55 AM
TimC300's Avatar
I would get out my multimeter and test the connectors at the sensors. Im not really sure how they operate, im guessing closing the hood closes the circuit. There should be two wires coming from the connector. The ignition may need to be turned to on to test.
Check for power. If no power check each ground wire for continuity.
I looked up the wiring diagrams. Its for my 2010 but should be similar or the same for 2012. Brown wire is the ground, each sensor has different ground locations. I believe the right sensor + goes to the front SAM (N10/1) or to the front Prefuse (F32), the left sensor + goes to the rear SAM (N10/2).
Not entirely sure. The diagrams are confusing.
Old Mar 25, 2025 | 01:27 AM
Dave Hart's Avatar
Thanks Tim. Sounds like the right way to start, I'll do that with my multimeter and let you know how it goes.
Old Mar 25, 2025 | 12:51 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
All 204 models should be the same, but I have not actually worked on a European one. The switches seem very sensitive to proper alignment.
Old Mar 25, 2025 | 05:58 PM
RobertR728's Avatar
Here's something to try maybe?
Old Mar 25, 2025 | 11:55 PM
Dave Hart's Avatar
Hi Tim.
Here's what I've found.
I've got a good earth connection from the earth side of the connector to ground on both connectors.
With the ignition on, measuring the voltage on the input side of each connector, I get 5.2 volts on the passenger side and 1.8 volts on the drivers side (right hand drive). Seems a bit strange.
I've checked both switches with the latches in the closed position, and both are working properly with zero resistance between the terminals of the connector plug.. I even put a jumper wire between the plug terminals to simulate the bonnet closed situation, but still got the waring message.
It appears that the problem might be something other than the latches and sensors.
Cheers
Dave
Old Mar 26, 2025 | 08:41 AM
Odd Piggy's Avatar
Yes. Wiring, harness connector, maybe front or rear SAM.
Old Mar 28, 2025 | 07:25 PM
Dave Hart's Avatar
Yes, I think you may be right , SAM sounds like the most likely culprit . We've had a very intense wet season in North Queensland.
Old Mar 30, 2025 | 08:39 PM
TimC300's Avatar
The drivers side/right side seems low, though I have no idea what it should be reading. I would guess it would be 5-6v like the left side.
Did you try checking voltage of the + wire on that connector against the cars battery? Connect your + on the multimeter to the BNBU wire then your - on the multimeter to the + battery post. Curious if its higher than the 1.8v. Rule out a bad ground.
Old Apr 1, 2025 | 11:30 PM
Dave Hart's Avatar
Thanks Tim.
The reading on the BNBU side of the connector shoal have read 1.2volts instead of the 1.8 volts I put in my previous message.
So the voltage from the BNBU terminal to earth is 1.2 volts, and from the BNBU terminal to the + battery terminal, as you suggested, is -11 volts
