Gas cap loose sign and fuel light blinking.
Old May 1, 2025 | 05:09 PM
Obi3ice's Avatar
2008 c300 4MATIC Sport
Hi. Please what could be the issue with the fuel light blinking and gas cap loose sign popping up. I have changed the gas cap and it still happens once in awhile. Please see video.
Old May 1, 2025 | 07:39 PM
TimC300's Avatar
Since the check engine light is on and the gas light is blinking I would say scan the car with a Mercedes specific obd scanner.
Probably an issue with the evap system.
Old May 1, 2025 | 09:01 PM
streborx's Avatar
Top Answer: 1
G550
Sounds like someone siphoned your gas tank empty (but probably not).
Old May 1, 2025 | 09:02 PM
JettaRed's Avatar
Veteran: Army
Did you replace the gas cap with a Genuine Mercedes gas cap?
I tested an aftermarket cap that I got through Amazon Vine and after about a week, I got a CEL and code for the evap system. Put the "old" cap back on and the error never returned.
Old May 1, 2025 | 11:55 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The last time I saw this, the evaporative canister had a crack in it. But there are a couple of valves in the system that can fail, too. Scanning with an MB dedicated device as suggested is a necessary step.
Old May 2, 2025 | 12:39 AM
Obi3ice's Avatar
the check engine light came on immediately the gas cap loose sign popped up and fuel light indicator blinking. I scanned and the code that keeps popping up is P0455.
Old May 2, 2025 | 12:42 AM
Obi3ice's Avatar
Yes I did.
Old May 2, 2025 | 12:43 AM
Obi3ice's Avatar
The evap canister was checked and no visible crack was found. The code that keeps popping up when this happens is P0455.
Old May 2, 2025 | 12:45 AM
Obi3ice's Avatar
Also I noticed gas smell around the gas cap. I thought it was the evaporation canister that was why I had it checked for visible cracks but was intact.
Old May 2, 2025 | 01:20 AM
Odd Piggy's Avatar
P0455 = big leak. If you have local emissions stations, have them test your cap even though it’s new. Don’t test the car, because they’re required by law to flag it if it fails. If okay, either the purge valve is bad, there’s a hole/crack in the filler neck, the tank is leaking at the neck, or maybe the fuel pump cap, the crossover tube cap (less likely).
Old May 2, 2025 | 01:19 PM
TimC300's Avatar
I had a check engine light before and it came with a code for the purge valve, it was a simple fix. I dont remember ever seeing the gas warning light ever coming on from it. The another time after getting gas a warning on the dash came on saying to check the gas cap, but it went away pretty quick and I dont think the check engine light ever came on from it.
I looked at the manual for that code and also checked how the car tests. Heres that page : https://charm.li/Mercedes%20Benz/201...st%20Function/
Im assuming you have the M272 engine.
Old May 3, 2025 | 12:00 AM
Odd Piggy's Avatar
Good catch on the fuel tank pressure sensor possibly going bad.
Old May 3, 2025 | 06:12 AM
Obi3ice's Avatar
thanks for this information. Would check the fuel pressure sensor.
