M271 evo long crank
Old Jul 29, 2025 | 12:49 PM
duratorq's Avatar
M271 evo long crank
I own a W204 c180 with the 1.8 M271 EVO engine. I bought it at 110,000 km, and it’s now at 180,000 km. Since I purchased it, the car occasionally has extended cranking times(2-3 seconds). The camshaft adjuster and timing chain were replaced at 100,000 km. I suspect the high-pressure fuel pump, but there are no fault codes. The car drives fine otherwise. I’m looking forward to your recommendations.
Old Jul 29, 2025 | 01:34 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TROUBLESHOOTING LONG CRANKS
You've hit all the right suspects. Now let's get this starting up normally.
The key is not to replace good random parts.
First well troubleshoot what's wrong.
1 -- Connect your scanner to read tank + rail fuel pressures.
2 -- Scan whole chassis for faults in particular ECU for correlation CPS faults.
Post test results.
Old Jul 29, 2025 | 01:37 PM
duratorq's Avatar
Doğru noktalara değindiniz. Şimdi normal şekilde çalıştıralım.
say something
Old Jul 29, 2025 | 01:46 PM
"tee - shey - koor - hay - drin".... is as far I can stretch it
Old Jul 29, 2025 | 05:17 PM
duratorq's Avatar
Post test results.
No fault code on xentry. Connected 4 times
Old Jul 29, 2025 | 05:33 PM
No fault is good preliminary news.
Now you need to read engine data with Xentry.
>> read ( tank + rail ) fuel pressures.
Old Jul 29, 2025 | 05:36 PM
duratorq's Avatar
It's been this way for about 80,000 kilometers. The problem has neither gotten bigger nor smaller. I'll check where you said.
Old Jul 29, 2025 | 07:34 PM
while you're at it grab the fuel trim values at idle. This will confirm fuel supply.
Old Sep 3, 2025 | 09:19 AM
duratorq's Avatar
Arızanın olmaması iyi bir ön haber.
Şimdi Xentry ile motor sistemlerini okumanız gerekiyor.
>> (depo + ray) yakıt basınçlarını okuyun.
Fuel pressure is 1.5 bar. It should be min 4
What is your diagnosis?
UP UP UP
Old Sep 3, 2025 | 02:55 PM
LOW FUEL PRESSURE
UP UP UP
Great.... almost repaired!!
The 25psi pressure should be near 60psi.
In-tank fuel pump or filter are bad.
Inspect for bad connections then replace new.
