Strange noise on cold start
I’m getting a strange noise during cold starts, it lasts for about a minute and then goes away.
Please check out the sound in mp3 file attached till the end, you can clearly hear it there.
Is this a normal sound, or should I be worried about something specific?
Thanks!
C250, 2011 4MATIC.
After doing some research and listening closely to where the sound comes from, I’m almost certain it’s the air pump. Technically, it’s working fine, no error codes or anything and it shuts off on its own after a minute. It probably just kicks in when the temperature outside is around freezing.
Thank again!
It should turn on at cold starts and run for 40 seconds. Its for emissions to get the cats hot quickly.
Depending what obd scanner you have you should be able to function test it. If you do the manual says dont run it longer than 2 minutes.
