W204 SAM module fire, replacement issues – multiple electrical faults afterward
Old Jan 28, 2026 | 04:13 PM
Ahmed642's Avatar
W204 C320 CDI
Hi everyone,
I’m looking for some guidance regarding a SAM module issue on my Mercedes W204 C320 CDI Amg package with harman that turned into a bigger electrical nightmare.
Last summer, the following happened:
I locked the car, but the right rear tail light stayed ON, with the indicator stuck, even though the car was completely off. After a few minutes, the SAM module overheated and caught fire. I managed to extinguish it before the damage spread further.
I replaced the SAM module, but:
  • I could not find the exact same reference as the original one
  • The original SAM was completely destroyed, so coding/cloning from it was impossible
Since installing the replacement SAM, I’ve been dealing with several issues:
• Rear electric curtain no longer works
• Error message: “rear backrests unlocked”, even though my car does not have folding rear seats
• Random battery error messages appearing without a clear pattern
• Left indicator stops working and throws an error if it’s used for too long
At this point, I’m wondering:
  • Is this likely due to incorrect SAM variant / coding mismatch?
  • Could there still be wiring damage or a short circuit from the original fire?
  • Does this require SCN coding with Xentry, or a specific SAM part number?
If anyone has experienced something similar, or knows which checks I should prioritize (ground points, CAN lines, SAM variants, coding), I’d really appreciate your input.
Thanks in advance 👍
Spoiler
Old Apr 6, 2026 | 12:52 AM
codename47's Avatar
2005 Mercedes Benz C200 Kompressor
Originally Posted by Ahmed642
Hi everyone,
Thanks in advance 👍
Spoiler
Did you fry the front one or the rear one ?
Rear one I am not sure if you need coding if you get exact part.
Front SAM if you want to get it to work, you need exact part and do SCN coding.
Old Apr 7, 2026 | 03:12 PM
TimC300's Avatar
For the rear electric curtain and the rear backrest i'm wondering if the launch obd scanner is able to change those settings to active/not active. I have a Foxwell NT530 and while it does alot it doesnt let me go in and change anything with the car.
Old Apr 7, 2026 | 07:44 PM
bazzbazz's Avatar
C200 w204
Anyone else having flashbacks to "Two and a Half Men" when Candy's car caught on fire . . . . . . . ?
Alan: So how much to fix the car
Mech: For you good sir . . . . . $3000 dollars
Alan: $3000 DOLLARS! ARE YOU NUTS?
Mech: I remind you sir . . . . the car WAS on fire . . . . .
Old Apr 8, 2026 | 01:43 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
As far as I can tell, the Launch MB II can’t change anything that can’t be accessed from the engineering menus. I don’t have the W/X204s any more, so I can’t go dive deeper.
Old Apr 8, 2026 | 08:06 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
You don't say if it's front or rear Sam but they both have allot of settings.
Usually if you get a Sam from the exact make and model it can be plug and play. Butt if it's a Sam from a different car it will need to have three varients changed to match your car.
This is going to require DTS Monico or Vediamo PC softwares to accomplish this. And probably a little trial and error to get all the accessories working correctly.
If you don't have any of the PC softwares you will have to get them or get someone to remote login and fix it for you. If you need someone or the software message me and I'll try to get ya some help.
Old Apr 8, 2026 | 08:32 PM
AlexMonroe75's Avatar
I've got experience with the W204 SAM module fire issues, and yeah, replacing it can indeed be a nightmare, especially if you're not careful with the electrical system. I've seen multiple folks here on the forum having to troubleshoot electrical faults after replacing the SAM, so yeah, be prepared for some trial and error.
Old Apr 9, 2026 | 01:21 PM
RobertR728's Avatar
Dunno where you're from but if you can find the right part from the correct donor vehicle on ebay or something that would be the easiest way forward.
