Bank 1 & bank 2 too rich
I just solved this issue 2 weeks ago and it came back. But the thing is now , is that I literally feel nothing wrong with my car . It’s driving great , there is zero noise , no vibrations . Cleaned my MAF sensor 2 weeks ago. I’m gonna check the air filters after this snow storm . Maybe there’s my issue . But I want to hear another opinion .
Ive scanned everything, found nothing. found an article that points to the MAF sensor as the most likely culprit.
is the a way to test this sensor?
I just solved this issue 2 weeks ago and it came back. But the thing is now , is that I literally feel nothing wrong with my car . It’s driving great , there is zero noise , no vibrations . Cleaned my MAF sensor 2 weeks ago. I’m gonna check the air filters after this snow storm . Maybe there’s my issue . But I want to hear another opinion .[/QUOTE]
can you read your fuel trims?
Have you cleared faults from your ECU after recent MAF service... do it.
was diagnosing the car for being rich and this happens . Looks like my belt kinda burned the groves . This is a whole new problem
Ultimately at least replace belt kit: tensioner + idlers + serp. (+ accessories).
This job starts with a belt kit ~$150 + TBD. failed accessories.
- low fuel pressure
- old Lambda upstream sensors
- Overgapped spark plugs
- dirty MAF sensor
- oily MAP sensor
Many ppl know that RAIN LEAKS can royally mess up MB. I bet salty snow can pack a treat too...
Pop the hood open,
use your scanner,
investigate reality...
Dealer are here to help with trained technician who can diagnose your issues often for a small fee.
Someone needs to assess the accessories to make sure only the tensioner caused the slippery belt failure.
The service of serpentine accessories is really not time consuming nor too expensive if nothing else
Sorry for this being late!
there is ways to test the sensor depending on what scanner device you have . Have you solved your issue ?
Pop the hood open,
use your scanner,
I don’t want to just ignore this and wait till it progresses lol it just confuses me a bit .
But that rarely occurs .
I don’t want to just ignore this and wait till it progresses lol it just confuses me a bit.
- Engine (..., pigtails, good oil, ...)
- Transmission ATF
- Suspensions (SB links, arms, BJ, ...)
- Tires + Brakes services
- Leaks: oil, coolant...
- Batteries (trickle charge,...)
Your MB likes any new genuine parts & care you give it.
"Bk1+2 too rich" brings ignition up to the head of the list.
opportunistic free loaders soaking sun 👏
