- Mercedes-Benz C-Class: Winter Tire Reviews
Reviews and comparisons of top products
Browse all: Tire Repair and Maintenance
What winter wheels/tires are you installing soon?
Unless you have no need for money, do not buy at the dealer! I paid less, 1300, for the rims and tires than I would have paid for only the rims at the dealer, plus the rims are good looking alloys, not "steeles". Tire Rack of course.
None of these choices have any effect on warranty as long as your choose the proper sizes.
The new improvement on both the blizzak and X'3s is H (130 mph) speed rating. They are otherwise very similar to their predecessors in design, Blizzaks still have the knobby edges Michelins are rounded:
http://www.tirerack.com/tires/tires....l=Blizzak+WS80
http://www.tirerack.com/tires/tires....odel=X-Ice+Xi3
Check the head on view of the tread and you will see where the big difference is.
The C Class is not the vehicle of choice for driving through deep snow no matter what wheel/tire combo you choose.
Again the 19 sotorezzos will be better than any all seasons on the same rims but worse than they would be on 18in higher profile tires. If you live in an area where there is only occasional snow they will do just fine. If you live in an area where snow is a 5 mth or more ordeal there are better choices.
In my area (north central WI) we don't get big dumpings of snow, in general they are 6 inches or less, however, the snow rarely melts, in fact snow happens when things get a little too warm. The snow that falls in November sticks around till March or April, plus, the other 20 other snowfalls in between!
Tires are not meant to be dismounted once they go on a rim, the next place should be the dump. Mounting and dismounting repeatedly greatly increases the chance of damaging the tires bead or chaffer. BTW the damage my not be visible leading you to possible (though rare) catastrophic tire failure. If you are going to use winter tires always have them on a spare set of rims. Much safer and much easier
No way, the more sidewall the more effective the tire! Its just that we all want to maintain the look of the car as much as possible. 19 might be too extreme to get the full benefits, 18 are a better compromise and 17 are the best.
For maximum snow effectiveness the trick is skinnier and taller! You want to dig into the snow.
