What does "selective damping" actually do?
Old Jan 26, 2015 | 11:49 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
"The standard selective damping can instantly firm up for sharper response
in corners, while maintaining ride quality on uneven surfaces."
I just saw this in a C-Class brochure and I'm not really sure how this works. What exactly is this and what does it do? I've never noticed anything unusual during hard cornering, so I'm curious about this feature.
Old Jan 26, 2015 | 12:31 PM
Glyn M Ruck's Avatar
Super Moderator
It's a calibrated mechanical bypass in the damper/shock absorber.
In Benz speak:
" The damping system provides for well-balanced ride comfort by optimising tyre vibration characteristics, damping and stabilisation according to the road surface conditions.
The AGILITY CONTROL suspension offers high ride comfort through selective adaption of the damping system to the prevailing road surface conditions. By continuously scanning the road surface it is able to improve ride comfort when minor bumps are encountered and to provide more effective damping and stabilisation of the vehicle in response to more substantial jolts.
The AGILITY CONTROL chassis combines the flexibility of a selective damping system with the effectiveness of a passive damping system. The comfort-oriented conventional spring/damper system is augmented as standard by a stroke-dependent damping function. The functional module of the selective damping system consists of an elastomer piston which offers the oil flow a bypass parallel to the conventional shock absorber plating when minor bumps are encountered. This reduces the level of damping in the +/- 10 mm range, markedly improving ride comfort and the tyre/road contact characteristics of the chassis. In case of heavier impacts on the chassis, the selective damping function activates the full damping effect. "
Effectively a passive variable rate damper dependent on road surface input to the suspension.
Old Jan 26, 2015 | 12:51 PM
StanNH's Avatar
Glynn, the explanation refers to an Agility Control suspension. Are they saying that Agility does have an effect on the steel suspension damping? Is damping reduced in Sport as compared to Comfort? It has always been my understanding that Agility only worked with Airmatic, and not with any steel variant.
Old Jan 26, 2015 | 03:42 PM
Super Moderator
Stan ~ you need to move back to the W204 to understand the agility control suspension progression
1) Agility Control = Passive variable rate dampers with steel suspension (intelligent dampers)
2) Advanced Agility Control = Active magnetorheological dampers with sensors, controller etc. switchable with steel suspension.
3) Latest W205 Agility Control = Variable, switchable with Airmatic.
Option 2 with steel looks as though it will come back with C450.
Yes ~ W205 with stock steel suspension uses option 1.
Old Jan 27, 2015 | 10:32 AM
Super Moderator
BTW ~ I understand the confusion in this regard. Benz promo literature is almost deliberately confusing. Marketing people taking license.
Old Jan 27, 2015 | 10:41 AM
StanNH's Avatar
I'm used to the PASM on my Porsche which, apparently, is nothing like what MB is using here.
PASM: "Sensors record all wheel and body movements. This enables intelligent adaptation of damper stiffness for the selected mode, optimizing contact between each individual tire and the road for even less roll and pitch."
I guess the steel suspension used by MB is not electronically regulated, so I see it more as non-selective than selective since the driver has no control of it. And it looks like "Agility Control" has no relation to "Agility Select." Very clever marketing.
Old Jan 27, 2015 | 10:51 AM
Super Moderator
The Advanced Agility Control (active) does basically what PASM does. SA motorists want it back instead of Airmatic. Rumour is that it will be offered shortly here on W205. SA motorists loved it on W204.
Old Jan 27, 2015 | 11:03 AM
solarflare's Avatar
Mercedes C300, BMW X5
Yeah I was too confused by their term. I say it is quite misleading by hinting their stuff is more complicated. I too am more familiar with Porsche or BMW terms.
What bugs me is a couple reviewers stated that airmatic is not much better than the standard steel. Comfort mode seem too soft and leans too much in corner. The sport mode is just right. Yet, you can achieve the same thing with steel default. That should not be at all possible with amplitude based damper. I suspect they road in some reasonable roads.
Anyways, I like the steel suspension until I hit "travel" or adjust limit. It only happen in one stretch of road near my place. Every car I test drive it has a hard time with that road. Only my SUV seem to handle that road reasonable well but still annoying.
Old Jan 27, 2015 | 05:48 PM
Sol01's Avatar
2013 C class Coupe 250 CDI
was posted before in another thread
