Check your Oil Level
Edit: & yes, fouled inlet valves have a marked effect on performance. It can get a lot worse than my Porsche picture. That was a low miler
Audi intake.
General.
Newer designs have various solutions to lessen this possibility but those engines are just hitting the market.
Also just because you don't see the problem in South Africa doesn't mean the problem doesn't exist. One of the main factors besides design is the way one drives the car or location. You being in South Africa you don't deal with cold weather. DI engines need to be driven hard to increase engine temps which reduces the carbon build up because it provides a cleaner burn. Customers that live in cooler weather climates are much more susceptible to carbon buildup because in the winter months the engines may not be able to warm up to operating temps between work and home.
Just because you don't run into these problems in South Africa doesn't mean the problem doesn't exist.
Don't take my word for it but if you want to argue with a mechanical engineer with a MASc who has worked on Formula SAE then you go right ahead.
Here is the link http://www.thetruthaboutcars.com/201...in-a-nutshell/
The article does not disagree with anything I've said. I did not say the problem was confined to VW/Audi (VAG) Group & Porsche. I merely used them as an example & because I had pics of their problem & fix.
What I am saying is that Direct Injection engines are a lot more susceptible to oil consumption due various factors such as poor fuel, engine operating temp, carbon buildup, design than port fuel injection cars of the past.
Heck in some places MB had problems with carbon build up with engines in the W203 cars which I believe where not DI.
This has probably been covered, but just making sure. Thanks.
The W203 M271 head fouling problem was due to head design for Euro 4 & 5 fuels at that time. On crap fuel they fouled & were redesigned from approx March 2004 production for less desirable fuels. Benz only sold W203 CGI cars in Europe that were DI as they required min Euro 4 fuel. ROW was port injection.
I remind you that you stated ~ "GDI engines will consume more oil because they are more prone to carbon buildup of the valves which in return will cause more fouling of the oil and hence more engine oil will be consumed"
Also note that the article you posted makes no mention of fuel dilution of crankcase oil. That will be because they have never found any. Also note that the first indication of fuel dilution is a rising of crankcase oil level. e.g caused by a badly damaged dribbling injector. This is however more prevalent in diesel engines.
I do hope with second generation DI engines from various manufacturers will fix this problem.
