Old Jun 24, 2015, 04:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Changing Center Console 95% done...
Old Aug 25, 2016 | 12:55 PM
  #51
gsd99mg1's Avatar
w205
Originally Posted by gile79
Part number for black ash center console w/o clock is: A2536803600.
Price here in Europe is 453€ (Geman store).
/gile79
Hi Gile,
I have two questions. Is that part number only for black ash or does it just correspond to the console and you need to specify the material when ordering? the web sites are not overly explicit, they just state part number and price.
Also, were you able to transfer ambient lighting to the new console?
Old Aug 25, 2016 | 08:14 PM
  #52
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Just mentioning it, IF YOU HAVE A CREAKY CENTRE CONSOLE.....
After removing my console to reduce NVH I noticed all the console elements, which are designed to be screwed to the rear of the console face, were misssing their screws !!!!
They were all only clipped in place.. cap QC MB!!! This led to a lot of creaking on the consle IF you pressed or pushed on it..
I used:
Self tapping screws I had to fix this.
Liberally applied silicone spray and plastic grease to plastic clip and plastic to plastic contact points
Foam backed dyna mat over the trans tunel / air vent section
Low density foam to the rear of the coin box..
All in it has made the area a lot more soild sounding, almost no creaks when pressed anywhere and zero noise when being driven turned across a ramp (torsional twisting of the car chassis)..
Mine was black wood from factory which I have no intention of changing.. it was also a good oppurtunity to polish out some of the super fine scratches on the controller and silver trims and coat them..
Old Aug 27, 2016 | 06:55 AM
  #53
medkm's Avatar
Mecedes E 220 c238
doing the same thing but the clock not working can you tell us please how to make the clock working
Old Aug 30, 2016 | 08:42 AM
  #54
gile79's Avatar
C 220 BlueTec 4matic
Originally Posted by gsd99mg1
Hi Gile,
Hello gsd99mg1,
Part number above is only for black ash, no problems to transfer ambient lightning to new console.
/Gile
Old Aug 30, 2016 | 11:28 AM
  #55
gsd99mg1's Avatar
w205
Hello gsd99mg1,
/Gile
Hi Gile,
Thanks for all your information. I am finding it difficult to remove the first piece of metal trim that covers the screws that secure the console in place (the piece where the button to open the armrest is located). I am afraid of applying more force and breaking it. Is it just a matter of inserting some flat metal piece (such as a knife) and wedging it up? Or did you need to unscrew or unlock any piece to loosen it first?
Old Sep 6, 2016 | 08:22 AM
  #56
Alfie3121's Avatar
C220
Hi Mate. Looks really good, I'm thinking of doing the same. Looks like you left the black air vents instead of buying the silver one. Looks good in the picture, but what do you think of it in the flesh?
Old Sep 12, 2016 | 07:33 PM
  #57
gsd99mg1's Avatar
w205
Hi,
Would anyone explain how to pry open the first piece of metal trim in order to access the screws which secure the console? It's not so clear in the video and photos. I have tried applying force but it doesn't budge and I'm afraid of breaking it. Is there any lock to undo before prying it open appart from opening the armrest doors?
Old Sep 12, 2016 | 07:52 PM
  #58
Shadwell's Avatar
Hey mate...
OK the easiest way i found was to pull slighty on the silver edge of the trim piece.. trying to pry the balck plastic at the join in the stowage box wasn't successful..
My methid was gently pull upwards on the silver plastic part (outer most edge of the section the button is in)..
As the part started to gap i used a plastic spatular to leverage it a little.. i left the plstic spatula under it and did the same on the other side.. at the same time i pushed the button down and pulled on the lip of the silver piece vertically upward..
afte a little wiggling it started to lift and i was able to leverage the back side (in the stowage box area)..
pulling straight up it comes away.....
Hope that helps.. the online videos work if its a loose fit but not if its one of the tight ones..
Old Dec 14, 2016 | 11:51 AM
  #59
medracr's Avatar
Audi A4
Originally Posted by RemmyZero
Nevermind, I found the DIY. Makes perfect sense now.
where's the DIY?
Old Apr 6, 2017 | 06:16 AM
  #60
2002328's Avatar
W202 C280
Can anyone help to give more information of wiring the clock, and the setting up for functioning the clock. Thanks.
Old Apr 9, 2017 | 07:09 AM
  #61
berniw99's Avatar
C250
Hi did you get the clock working ? If so how did you connect the wires please ?Thanks
Old Jun 1, 2017 | 06:36 PM
  #62
xclream's Avatar
R350
Did you ever get this to work finally? Would love to know more, thanks.
Old Sep 15, 2017 | 11:26 PM
  #63
amgburbles's Avatar
C63 AMG Coupe
/gile79
Thank you so much for sharing this. I wasn't able to order it with my car because of low inventory issues. Then I found out how much they were charging to get the clock installed version after my car was delivered. I asked parts department about fitment with the part number you posted and they didn't know anything about it but I went for it anyway. I replaced my center console in my C63 coupe and it was a perfect fit! I'm so grateful I found your post! I only wish it came with the AMG emblem on the lid
Old Dec 21, 2017 | 04:22 AM
  #64
KilianSC's Avatar
2018 GLC 300
Hi,
Hello!
I'm curious if anyone has any additional tips on removing this first trim piece and the center console. Also, are the video and photos describing the process still available?
Thanks very much!
Old Mar 22, 2018 | 02:10 PM
  #65
RichNY's Avatar
C300
[QUOTE=amgburbles;7265084]Thank you so much for sharing this. I wasn't able to order it with my car because of low inventory issues. Then I found out how much they were charging to get the clock installed version after my car was delivered. I asked parts department about fitment with the part number you posted and they didn't know anything about it but I went for it anyway. I replaced my center console in my C63 coupe and it was a perfect fit! I'm so grateful I found your post! I only wish it came with the AMG emblem on the lid
[/hi can you confirm what site you bought this ? I’m trying to do the same thing without the clock
QUOTE]
Old Mar 22, 2018 | 02:15 PM
  #66
RichNY's Avatar
C300
Just to confirm the glc trim will fit right in the C300 without any alterations?
Old Mar 22, 2018 | 05:56 PM
  #67
RichNY's Avatar
C300
Can someone that did this tell me how is the touch pad, climate controls and dvd and vents held in ? Just trying to confirm once I get trim off how do I take all the parts off of it to put in new trim ....
thanks all
Old Mar 23, 2018 | 12:51 AM
  #68
Yamdan's Avatar
C220 CDI 2016
thanks all
its easy just clips and a few screws. Did it a few weeks ago and you will see how it works when you get the consol out and look at the rear. No worries
Old Mar 23, 2018 | 10:02 AM
  #69
RichNY's Avatar
C300
Great thank you
Old Apr 3, 2018 | 10:12 AM
  #70
RichNY's Avatar
C300
Sorry one other thing do you know the screw size to remove the trim ? Mine comes today and want to have the tools ready
Old Apr 3, 2018 | 10:33 AM
  #71
Willow1308's Avatar
'17 C300C4 Coupe...and a couple of other fun vehicles…
I have a '17 C300C4 coupe...
I plan on changing my center console to the matte black wood trim...
Is the matte black wood trim avaible without the analog clock?
I wonder if the center console is the same for the sedan & coupe?
Old Apr 3, 2018 | 01:19 PM
  #72
mjs1190's Avatar
2018 Mercedes AMG C43 (sold), 2025 GLC63s Coupe
Console is same for sedan & coupe. The wood console without the clock is the GLC console which fits the C.
Old Apr 3, 2018 | 04:13 PM
  #73
Willow1308's Avatar
I greatly appreciate that information!
Old Apr 3, 2018 | 05:37 PM
  #74
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Will the ambient lighting work if my car never came with it originally?
Old Apr 10, 2018 | 09:01 PM
  #75
RichNY's Avatar
C300
Can someone tell me can I install just the center console ambient lighting ? The new ash wood appears to have some light bar all along the bottom so I assume I need the bulb attachment or something
