Noise after shut down - C450 - Turbo Cool Off
Old Feb 27, 2016 | 08:50 AM
Learning's Avatar
2016 C450 AMG, 2015 QX80
When I shut down the car, I hear a noise (fan/motor) sound for a few seconds after. What's that?
Also, wouldn't it be smart if the turbos cooled down a little before shutting the car off?
Old Feb 28, 2016 | 03:53 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
It's a fan doing what it is supposed to do, cooling the car off. Most newer turbo cars do this. The car is cooling off as you drive it, but turbos require more cooling once at rest, hence the fan you hear. Completely normal.
M
Old Feb 28, 2016 | 10:28 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Fan cooled turbos?
Modern turbos shouldn't need babying but you might help by taking it easy driving wise for a few minutes after a good blast.
The fans could be anything, main engine, electrical ballast, modern cars have all sorts.
Pretty sure the turbos are oil cooled tho, main fan is for engine block and ancillaries.
Old Feb 28, 2016 | 11:00 AM
Maritime's Avatar
2016 c450
M
At piggley, wiggley?
Old Feb 28, 2016 | 12:26 PM
ashap's Avatar
2016 C450
LOL
Old Mar 1, 2016 | 08:33 PM
Learning's Avatar
I've just seen turbo timers used for the cool down. But I haven't seen stock cars with these before. So I don't see it as that.
Old Mar 3, 2016 | 09:11 AM
Gonein4's Avatar
C450
If it is a ticking notice, There has been some issue with the hood cable falling into the Fan. Have a look. Just move the cable if that's the issue.
Old Mar 4, 2016 | 11:51 AM
Germancar1's Avatar
Aww you still mad because they ran you out the other thread?
M
Old Mar 4, 2016 | 05:35 PM
lbowroom's Avatar
C450
Yes, what you hear is a recirculating pump that continues to circulate oil through the turbos after shut down to cool them. Most modern turbocharged cars are using them now. No need to keep the car running before shutting down.
Such a relief to see suspensions being handed down from moderators to antagonistic members.
Old Mar 4, 2016 | 08:47 PM
ItalianJoe1's Avatar
2003 CL 600
Those auxillary pumps move coolant through the turbos, not oil, but yeah they can run for anywhere from a couple seconds to several minutes after shutdown to keep the temps from getting too high in the centersections of the turbos. Nothing new, those have been around for a long time.
The fan is no different, the PCM looks at temperatures when you shut it down, and has authority to run the fans as needed after shutdown to keep it from heat soaking too badly.
Old Mar 5, 2016 | 04:52 AM
ManiacGT's Avatar
I thought turbos were oil cooled?
Old Mar 7, 2016 | 04:06 PM
lbowroom's Avatar
C450
They may be both water and oil cooled. Honestly, I haven't dug in there to check the plumbing.
