Head-Up Display currently not available across all 2017 W205 C-class models
He said the former is the most common, but he's seen cases of the later. To be safe and ensure I don't delay my order, I removed it and told him I'd add it later if he/I heard more promising news on the supply issue.
1) Add HUD to my existing order as soon as it's available, at some point between now and the deadline by which changes can be made to that existing order currently scheduled for Sept. production. I am willing to accept a further-delayed production date on the existing order if necessary. This is likely the best case scenario option.
2) If we get to the last day by which changes can be made to my existing order scheduled for Sept. production and HUD is still not available to add, cancel that existing order and create an identical, new order with the HUD at the earliest date it's available to order. If for some reason it becomes possible to create a new order with HUD meanwhile still not possible to add to my existing order, create that new order ASAP and either cancel the original order or keep for dealer inventory; or
3) If there is or there becomes another order with config. like mine in Netstar that has HUD confirmed with a production date for US delivery, see if we can do a trade on that car to get it at MB Plano.
Engine start position at 1.
At the steering wheel, press two buttons at the same time (one first then the other, but I don;t remember exact order).
Left, the return button.
Right, the phone (answer call) button.
This will take you to a hidden manual which you can adjust tons of things including HUD. I figured out it is nice to share.
Within the service menu there's a stack of sub menu options for configuring and testing the HUD. You can bring up various test images and shape the geometry of the image (i.e. width, height, warp, etc.). There's no options to configure fonts as he suggested.
[/QUOTE]Primarily it enables the position, form and shape of the HUD display.. almost exactly the same as the Screen display tuning options on your TV.. eg stretch / compress the form horizontally and vertically, tilt the form about 2 axis...
The text font is not an option to change, neither is the color...
In summary all this did for me was slightly increase the size of the display within its limits and tuned to my line of sight to make the form perfectly square (in perception anyway.. )
So while it is adjustalel but not in the way many would perhaps like..
I would like to switch bewteen speed and nav (current standard data) to performance, eg speed, rpm gear, oil and water temp and boost but thats too much to ask it seems.. (unless a C63..)....
Meanwhile, while these whiny workers are complaining because a so called "earthquake" apparently "destroyed their homes and factories", what are Mercedes owners expected to do to know their speed? Look down??
SMH, factory workers.
