C450 fueling issue.
Old Oct 11, 2016 | 12:22 PM
S500Sport's Avatar
2019 C43 Sedan
C450 fueling issue.
Hi.
Need some assistance..
Lately when I've been fueling up I get pauses from the fueling hose.. so I fuel the car and then the pump stops.. (mind you the tank is not full).. I start fueling again and it stops.. this continues on and on..
I heard that this is because there is air in the tank? How do I rectify?
Thanks.
Old Oct 11, 2016 | 12:27 PM
cenzo86's Avatar
2016 c450 / 2016 VW Jetta 1.8t / 2006 Wrangler X
I have the same problem every few fill ups. It happens when I'm on E and even a half tank. My dealer couldn't duplicate the error. Mwop mwop.
Old Oct 11, 2016 | 12:32 PM
S500Sport's Avatar
2019 C43 Sedan
Old Oct 11, 2016 | 12:37 PM
MASSC450's Avatar
2026 GLE 53 Coupe
Never had this problem filling up my C450...then again I never squeeze the fueling level fully or try to jamb the fill cap in the handle like the lazy people do.
Old Oct 11, 2016 | 03:13 PM
alexasa's Avatar
c
This has happened to me in my last few cars.
I just remove the nozzle and re-insert. It's almost like you have to find the g-spot at times.
Old Oct 11, 2016 | 05:12 PM
GerritKw's Avatar
C350e
I have it sometimes too.
Think it's also related to the sensitivity of the fuel grip. But usually taking it out or wiggle it a bit helps.
Old Oct 11, 2016 | 06:56 PM
Xtrema's Avatar
2020 GLC43
I think I do get that when I get gas from randoms on long trips and usually move it out a bit and not inserting it as far seems to work.
Old Oct 11, 2016 | 07:53 PM
cenzo86's Avatar
We're still talking about gas now right?
Old Oct 12, 2016 | 10:02 AM
MJ83's Avatar
2016 C450
Try backing out the nozzle a bit, that usually works for me.
Old Oct 13, 2016 | 01:13 PM
tivoboy's Avatar
2016 C450 AMG, 2009 C300, 2001 C320 2001 CLK430, 95 E500
I think this is more about back pressure in the tank, or nozzle than another else. It changes for me with the weather. Usually a pull out slightly (don't read into that one!) and re-insert will get it moving fine again.
Old Oct 17, 2016 | 08:21 PM
Trancebolt's Avatar
w212 E350 Bluetec & Mk7 GTI Sport
My 2015 C300 had its fuel tank replaced 0_0! It was filling up, but it would kick the fuel line at half a tank, and never went above that. Very strange.
Old Oct 18, 2016 | 09:43 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
I've had this problem on and off with both of my C300's. At one point I had the vent valve replaced. That fixed it for a while, but then the issue returned. Recently, I complained about it to my dealer and they replaced another part of the venting system. Since then it has been fine, and I can fuel the car with no problems at all.
The dealers can check on this, and will replace parts if needed under warranty.
