Door Sill Removal
https://mbworld.org/how-tos/a/merced...r-sills-388889
Just gently pry them upward until they disengage.
I'm always hesitant with this kind of disassembly work when I don't have clear step by step instructions (preferably with pics) because I have broken a couple minor pieces in the past pulling on parts when it wasn't clear how they were attached/should be removed.
Looking at the back of the replacement sills that I want to install, there really isn't any hint as to how they attach (and would be removed). Anyone else have any experience with these?
There's a thin fragile wire ribbon on the back side for the illumination.(the white ribbons)
Use fishing line or a very thin plastic scraper to slide under the sill and work it down the length to break the bond of the tape.
Be careful, wire harness will rip easily.
or maybe this small rubber circle, but under it I can not see any female connector
btw. installation of new sill is very easy as they have two centre points which need to jump in first
all what I need now is part numbers of wires and control unit, someone maybe has it please?
so
