Car Jolts During Hard Acceleration
Old Apr 27, 2017 | 04:56 AM
patrickarguello's Avatar
C300
Hello!
i am currently driving a 15 C300 with 25k on it. A few weeks ago I started to notice a single jolt during hard acceleration. This later turned into multiple jolts usually between 70-80mph. The vehicle will shift back and forth as many as four times. It's almost as if the car is struggling to accelerate. This evening on the freeway I decided to push the transmission to the limit and see if I could notice a change in the gears or fluctuation in RPM when it happened but nothing. It jolted four times tonight at about 75mph when I had the pedal all the way down. After this it appeared that the car struggled to maintain any speed above 70mph. I also turned off all music and noticed a humming during acceleration above 70mph that wasn't there before. I've already had it checked out by the dealer. Tech put on 16 miles but couldn't locate any issues. No codes, lights, or anything. Any thoughts? I'm hoping this new humming or a drive with a tech can identify what's going on. My guess is the transmission is failing pretty early.
Old Apr 27, 2017 | 07:19 AM
Mike5215's Avatar
2016 C300
Are the RPMs staying steady during the jolts or surging?
Old Apr 27, 2017 | 08:57 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
If the RPMs are steady and power drops out, that sounds like a misfire situation. If RPMs are surging, sounds like tranny problem. Either way, I'd think codes would be flying left and right when it happened
Old Apr 27, 2017 | 12:40 PM
C300
Hi Mike,
Thank you for following up. Yes the RPMs remain steady during the jolts. While accelerating hard I stared down at everything looking for a light or a change in RPMs, but nothing.
Old Apr 27, 2017 | 12:58 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
I'd hazard a guess at injectors.
Old Apr 27, 2017 | 04:35 PM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Just take it to the dealer.
M
Old Apr 27, 2017 | 05:25 PM
Mike5215's Avatar
2016 C300
It's been to the dealer. No codes and cannot reproduce.
Old Apr 27, 2017 | 08:13 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Try a reset in the car by holding down the CD eject button for several seconds. After the reset, try re-establishing your connection.
Old Apr 27, 2017 | 08:32 PM
removedCFGaccount's Avatar
Former Member
CLS
Really?
Old Apr 27, 2017 | 09:33 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Step away from the keyboard Stan.
Old Apr 27, 2017 | 09:36 PM
Former Member
CLS
What's the frequency, Kenneth?
Old Apr 27, 2017 | 09:39 PM
Mike5215's Avatar
2016 C300
I think he thought he was posting in the thread about Bluetooth connectivity.
Old Apr 28, 2017 | 01:57 AM
janusgrimnitz's Avatar
C200 4matic
hahahaha
Old Apr 28, 2017 | 03:14 AM
C300
Hahahaha wow.
Old May 2, 2017 | 11:05 AM
C300
Alright so I got back from the dealer yesterday and apparently someone had the same issue and they were able to pull a crank shaft sensor code. The car has to accelerate long enough through the jolts to pull the code. It's been replaced and no further issues noted at this time.
Old May 2, 2017 | 11:48 AM
Former Member
CLS
Uh, Kenneth, what got replaced?
Old May 2, 2017 | 12:13 PM
C300
The CD player got replaced Peter
Old May 2, 2017 | 12:14 PM
Former Member
CLS
Ah, a frequency change....
Old May 2, 2017 | 06:19 PM
DBOC205's Avatar
W205 C250BT
Intermittent issues can be a real pain - especially if you're trying to show a dealer or service centre and then there's nothing wrong when they drive the car. I would try the following:
- Get a Bluetooth OBD dongle and buy the 'Torque' app. There's an additional plug in which lets you merge video and the diag data onto the one screen.
- Go out, do some testing and record the event which is bothering you, so you can show that to the dealer along with the log data.
Old May 2, 2017 | 07:03 PM
ItalianJoe1's Avatar
2003 CL 600
We've had one or two 205's with a flaky CKP. They are a ***** to troubleshoot as if the RPM signal drops out momentarily, the car doesn't really think it's an issue, it doesn't set a code right away. We've had the field rep there with a car having a similar issue and even he acknowledged that they don't have a real fix for it, but so far every time we've replaced the sensor it goes away. I think it's just a batch of bad sensors, only been a few cars though.
