Upgrading headlights (C class W205, sedan)
so I want to change the headlights on my C class W205, before I buy the LED headlights I had to be sure if that is even possible.
What's the process of upgrading from this:
To this:
Will the headlights turn on slowly when I unlock my car like I've seen on internet?
Thank you!!!
Last edited by MBFTW_111; Feb 13, 2018 at 05:37 AM. Reason: Forgot to write something
Also the dealer charges $1900 for light package so if you got your car for a good deal you can still come out ahead. I am pursuing an oem upgrade right now, and I can tell you it is not going to be difficult. It isnt plug and play, but it is fairly straight forward. If you have static LED it is even easier especially for USA version.
I havent 100% confirmed yet but due to USA headlight restrictions on the ILS system, the level sensors on front and rear may not even be needed. Just headlights, a few wires added to current connector, camera in windshield.
My car luckily came with windshield that had camera space built in. For some, they would need to change windshield to get auto brights feature. But they could still install ILS to get lights and look.
My car is 2014 C220 cdi w205 and I live in Croatia but the car is from Germany. Are static LED headlights easier to install? I really want them because those headlights improve the overall look of the car a lot.
buy harness from here
https://www.kabeldaviko.de/product_i...e-631-632.html.
install rear level sensors and wires.
change headlight switch
install static headlights.
code IC, front sam, headlights, ignition module and and they should work.
a lot of connecions are same as ILS, so if you have windshield i would recommend doing ILS if you are already putting in all this work.
Essentially, you upgrade headlights and control modules on the head light. Run 1 extra sam wire per unit. Run extra power per unit and put in camera in windshield (may need new windhsield depending on car you have) and then code and youd be done.
Most of us don't have access to the coding anyway. And dealers would definitely say no to this kind of project.
. So headlights are a breeze.The first thing I did, was spent $60 for 24 hour access to mercedes startek info. this gave me access to all of the wiring diagrams needed for headlights
Not to down what you did, but $60 would have saved you a whole lotta time rather than trying each individual pin and risking frying something. I am debating whether to share these documents to everyone for free. Becuase not only did it take a little money, it took me hours to make my own pdf catalogue off all the headlight wiring assemblies and of everything they connect to with the legends. I also have a few others that people may be interested in
I only have 1 question I have not been able to figure out so far, and its not due to wiring diagrams. Mercedes does not specify the use of level sensors in the USA vs Europe vs asia etc. That is why I have been asking for pictures of peoples ILS headlight connectors, because I am trying to see if I can group certain cars with and without the level sensor wiring and make a pattern. But so far, in the USA, the level sensor wiring seems totally random. Some have it and some dont. But in the USA since we have "dumb" ILS, I do not think our cars use the level sensors, which makes this upgrade extrememly easy.
So anyway, for halogen to ILS
You must run all new wires. Must change headlight switch, must change headlights, then must code front sam, insturment cluster, and ignition switch control module. If you want a true ILS, you may or may not have to change windshield depending on if you haave a camera already or not, then you will need to run wiring to camera. All this does if give you the auto high beam. if you dont install the ils will function the same as static or halogen high beam.
Level sensors are TBD. But in the USA i do not think you need them. as far as I can tell, the usa models do not use this input. Its not an easy task, but if you know what you are doing the upgrade is not that difficult.
Not to down what you did, but $60 would have saved you a whole lotta time rather than trying each individual pin and risking frying something.I am debating whether to share these documents to everyone for free. Becuase not only did it take a little money, it took me hours to make my own pdf catalogue off all the headlight wiring assemblies and of everything they connect to with the legends. I also have a few others that people may be interested in
All I wanted was for the lights to turn on, so even if it's static, it'll still be great. My wife's car has ILS, and to be honest, aside from being really bright, I couldn't notice the ILS function.
There's one issue I don't know how you're going to solve is that the source current for the DRL would not be stable. It seems it's not enough to power the DRL from time to time. My guess is because the original DRL led consumes much less power than the one in ILS, so I don't see a way to fix that.
The ils and static led have control modules in them (microprocessors computers etc), thus everything is operated by the peripheral can bus network. Once power is distributed through the bus (2 ground and 1 power connector for static and 2 gorund and 2 power for ILS), the control modules light the led lights. The halogen lights are simply old school and run by putting power to them. There are dc to dc converters built in and all is handled at the headlight depending on can signal and front sam inputs.
You simply can not upgrade to static or ILS lights without coding. I use the term coding loosely because the code is already there in your ecu and modules. You just must enable and disable certain strings. sometimes minor writing is needed, but for this you are adjusting lines of code to enable them to do what you want. All you need is a Star diag system with vediamo to do it.
a dealer *may* be able to do it. but unless they can add to your vedoc to get code from Daimler, they must hard code through vediamo or dts monaco. they will most likely charge a pretty penny to do this. and keep in mind this is only if you install all the hardware. but if they cant get it in a reasonable amount of time or if you did something wrong, you will most likely get turned away and be out a lot of money.
if you are USA based, I have almost verified, that we do not use the level sensors for our headlights. so wiring is much easier. the kabel daviko harness is probably your best bet still but you will not need all the wires as he says.
i would buy a knock off sds from ali express and pay someone to code it. mhha auto has a lot of people on there and info. Once i do mine id be willing to help you out as well. but i havent done it yet so not ready to commit. but i have laid the road map out and its not too bad. the halogen to any of the led is much more involved.
