How to remove the distronic plus star
Old Jun 9, 2018 | 10:29 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Lightbulb How to remove the distronic plus star
I have distronic plus on my 2015 w205. How do you remove the star from the grill? I am concerned about breaking it.
I read that you insert a wedge at the bottom of the star point and pry open at the top. I tried, but no joy.
(image is not my car)
Old Jun 9, 2018 | 11:13 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Worth a shot
Old Jun 10, 2018 | 12:42 AM
sentralfyr's Avatar
2015 S205 AMG
I did not use any tools on my 2015, just twisted left, and the distronic was not on the star, it sat on a braket further in
Old Jun 11, 2018 | 07:02 PM
benzdude's Avatar
Top Answer: 1
I figured it out! On my 2015 W205 Sport with distronic plus (the sensor is not mounted on the back of the star )
The star is twist locked (yellow) and has plastic clips (green).
Open your hood and insert your hand near the side (red). Push down (while twisting from the front) to turn the star anti-clockwise.
The star will turn and become a bit loose. You can now push on it from the back to release the clips and pop it out.
**Make sure to avoid the sensor.**
Part # A0008880011
Old Sep 4, 2019 | 10:28 PM
MariTheBoss's Avatar
2015 C300 4MATIC / 2017 C43 AMG
Hey Benzdude- first of all, I’d like to thank you for all of the inspiration for mods for my 15 c300 4matic I’m necroing this thread in hopes that you can provide me the part # of the black bracket; I purchased a distronic star on ebay (seemingly oem) and was confused about why it would not fit in the grill before I found this thread. I hope it is available separately from the A 000 888 01 11 part. Thanks in advance for your time and our collective wisdom!
Old Sep 5, 2019 | 05:47 PM
benzdude's Avatar
Top Answer: 1
What black bracket? A0008880011 is shown in my photo. That's the entire star.
Old Sep 6, 2019 | 12:47 AM
Hmm... I have the Part # A0008880011, in the OEM box, in my hands, and the shape of the cabin facing side of the emblem is not similar to yours it all (ebay link). Mine is the mirror emblem on top of a thin black base, but the base is nearly flat and does not have any indentations like yours that resemble the star. The part is also simply too big to fit in either my stock grill or my currently installed Muscle-Leopord diamond grill (ebay link). I figured you fit yours on by having what I thought was a black bracket protrude out of your grill slightly... Wrong, I guess... I feel like I'm doing something stupid... Thoughts?
Old Sep 6, 2019 | 01:19 AM
benzdude's Avatar
Top Answer: 1
Sorry no idea. You purchased an aftermarket product, not a genuine A0008880011 Mercedes part. (Even if if came in an OEM looking box)
Plus, no where on the Ebay listing does it say OEM part. Why don't you ask the seller?
That looks more like a A1648880411 star for CL CLA E GLA CLS G ML.
Old Sep 6, 2019 | 01:57 AM
I beat ya to it We’ll see what they say. “Fit all w205”... mmhmm... Interesting bc it has all the proper markings / part number engravings / made in germany marks similar to yours, just different layout underneath. Thanks for your responses!
Old Sep 6, 2019 | 02:07 PM
HAILERS2's Avatar
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
I found a much easier way to remove the Star on a S550 coupe. Last Wednesday I was behind a eighteen wheeler thirty miles west of Albuquerque. NM and he moved from the passing lane to the right lane and kicked up the thread off a rethread tire and it hit the front of my cars grille. Distronic stopped working right away and when I pulled into a gas station in Grants, NM I found the Star long gone and the distronic still not working.
Cars at Park Place Bodywerks, Ft Worth being fixed as of this morning.
Old May 20, 2020 | 08:06 AM
Andrew Jewell's Avatar
C200 W205 2015 AMG Line Estate - Brilliant Blue
Does anyone know whether you can fit the Emblem above (# A0008880011) on a non-distronic w205 grill?
Old May 20, 2020 | 11:07 AM
Allison's Avatar
2007 cls 63
2007 cls 63
Does anyone know how to remove the distronic star from an 07 cls 63?
Old Jun 16, 2020 | 03:21 AM
Armande Naseem's Avatar
2016 C450 AMG, 2003 CL 55 AMG
I know now to twist left as I rear ended someone and my star fell off, so I kinda twisted it back on and went on with my day. Stayed on for about 10k miles, eventually lost it while driving somewhere along the expressway. Replaced it now.
Old Jun 14, 2021 | 09:45 AM
Cosworth2000's Avatar
2022 E53 AMG
Part # A0008880011
What is the black circle just beside the bottom green arrow?
Old Oct 1, 2022 | 02:56 PM
Runs 10s's Avatar
AMG GTC
The following applies to my 2020 GTC and is not meant to be all inclusive. As you have probably found out by now the Distronic Star is an entirely different piece from the non Distronic. It does not "just screw off" from the front/outside. I just had to have mine replaced and it entailed removing the entire front plastics as well as some undertray. Also if your Distronic needs to be adjusted, many dealers don't have the correct MB tool. My dealer had to purchase it and it cost him $1200 for what is basically a modern headlight alignment tool. Yes, I know it's not that simple but that's what it looks like.
They then have to run the diagnostic software and test its alignment and then test the car. My dealer sail it took them 3 "adjustments" to get the bracket aligned properly.and to have the Distronics ECU accept it and turn off my warning light. It was not an inexpensive job.
I don't know if there is a true OEM illuminated star for Distronic but I have not seen one.
Old Jan 10, 2025 | 03:58 PM
4wheelbuilds's Avatar
Does anyone know the Mercedes part number for the distronic star for the facelift 2018+ model? I purchased a replacement grill for my 2015 C450 AMG, from a C43 but my distronic star now does not fit the new grill so I have to replace the star too.
The new grill has the mount as per the pic below, appreciate your help as replacement star is not cheap and I want to make sure I buy the right one that will also be compatible with the distronic.
Old Jan 10, 2025 | 04:41 PM
2022 E53 AMG
Is this a REAL grill? If not, just cut and glue the star into the grill.
