Cheap $30 center consol led DIY
Old Mar 25, 2019 | 01:15 AM
Jordan6252's Avatar
2018 Mercedes-Benz c300
So I decided to install led’s surrounding my center console because mine did not come with ambient lighting. I know they sell kits online for about $400 but i’m Also leasing my car so I didn’t want to start taking too much apart. And I know you could buy the center console light on eBay for about $100 but it’s from China and I heard about them overheating. So I went to amazon and purchased a basic led kit for $30 bucks (but you can get them way cheaper) and removed my center console and wrapped the length that I needed around the console and positapped the wires to I believe was the harness for my center clock for the power and it looks great.
I didn’t even have to take the entire console apart. Just wrapped the leds around it
I just connected it to red for positive and brown for negative
Old Mar 25, 2019 | 01:51 AM
Jordan6252's Avatar
Photos
I took some night time photos. The kit has an wall outlet so I cut the wire and just connected it to positive and negative. And you can’t even see the actual led strip itself when you enter the vehicle just the light.
This is the kit but you can use any kit you want
This is where I cut the wire from the wall outlet and posi tapped it
Here are some positive taps which are way better than t taps
Old Mar 25, 2019 | 06:36 PM
Jordan6252's Avatar
Yes I do but I put the receiver under the center console so I just have to pull the centers console silver plastic trim up just a little so it can connect, and change colors. But I usually keep it one color anyway
Old Mar 26, 2019 | 12:10 PM
JAMADOR's Avatar
2015 C300 Sport
Dimmable? Looks a little on the bright side for night use.
Old Mar 27, 2019 | 04:01 AM
Jordan6252's Avatar
Yes you can change not only the colors but also the light output with the remote
Old Mar 27, 2019 | 09:12 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Nice Lights, BUT WHERE CAN I GET THOSE MATS?
Old Mar 27, 2019 | 09:35 PM
Jordan6252's Avatar
They are really good quality and come in a variety of colors
Old Mar 28, 2019 | 09:38 AM
benzdude's Avatar
Top Answer: 1
Thanks,
What is your sellers name? (Not shown in the picture).
Also, can you take a better picture of the fronts and back mats and a really close view of the pattern. Pretty Please?
I am trying to decide if I should get brown w/ white stitching (like you) or black w/ red stitching for my black interior. (how did you decide?)
Old Mar 28, 2019 | 10:52 AM
benzdude's Avatar
Top Answer: 1
Originally Posted by BareQs
Poor guy is having his whole car replicated
who?
Old Mar 28, 2019 | 05:33 PM
JAMADOR's Avatar
2015 C300 Sport
How much work was it to remove the side panels of the console? I want to route a charging cable in the console rather than it being dangled on the side. And may look into an ambient lighting solution like this in the future.
Old Mar 28, 2019 | 10:27 PM
Jordan6252's Avatar
Originally Posted by benzdude
Thanks,
I chose the color based off my interior trim color which is brown.
I will take pictures for you in the morning when I wash my. Car
Old Mar 28, 2019 | 10:30 PM
Jordan6252's Avatar
Ill take take a picture in the morning of how I did mine, but it’s very easy and I used a flat cable that way I could have a clean fit and it goes into my phone for CarPlay
Old Mar 29, 2019 | 12:30 AM
benzdude's Avatar
Top Answer: 1
Thanks, I thought your interior was black like mine.
Old Mar 29, 2019 | 06:23 PM
Jordan6252's Avatar
Here are pictures of the mats
Old Mar 30, 2019 | 01:50 AM
benzdude's Avatar
Top Answer: 1
Very nice. I found these on Aliexpress. Expensive.
https://www.aliexpress.com/item/3D-C...944429703.html
Old Mar 30, 2019 | 02:24 PM
Jordan6252's Avatar
I was looking at those but I preferred the diamond layout instead
Old Apr 21, 2019 | 09:24 PM
J. L. McLovin's Avatar
C300 W205
No kidding......I was in the process of buying a LED tape to do the same thing......did you completely remove the console cover or keep it connected (by the wires) to the controls? TIA....Jon
Old Apr 22, 2019 | 03:45 AM
Jordan6252's Avatar
i kept it all connected. Just had to wrap it around
Old May 1, 2019 | 09:27 PM
C300 W205
Hey there......It's been a month. How's the system holding up? Has there been any problems after the install? I would like to do the same to my W205. Thanks in advance, Jon
Old May 4, 2019 | 09:09 AM
Ranz's Avatar
2015 C300
I see you purchased one with a remote/phone app. For the light to come on, do you have to manually turn it on with remote/app, or will it come on with ignition/accessory since it's hard-wired?
Old May 4, 2019 | 09:56 PM
Jordan6252's Avatar
I actually uninstalled it because I went ahead and purchased this instead since I wanted it to seem more stock since with this one you can control it from the factory switch in the car. But the one from amazon held up fine.
Old May 4, 2019 | 10:04 PM
Jordan6252's Avatar
it comes on automatically when you turn on the car
Old May 12, 2019 | 04:48 PM
C300 W205
So.....I decided to wait and see how you made out. Were you able to install it yourself? how did it go?
