Sound Deadening / Media / Audio Upgrades
Subscribe
Oct 14, 2019 | 02:47 PM
My car does that door squeak thing when they aren't lubed up.
Have you guys done anything to help assist with sound deadening?
Also, what are you guys running audio / speaker setup wise? I have the Burlesque(spelling) sound system and the 2015 NAV (No Apple Play). Anything decent aftermarket wise there?
Reply 0
Oct 17, 2019 | 02:33 PM
Quote: My car does that door squeak thing when they aren't lubed up.
I have the creaking door seals too and I bought all the stuff recommended like the rubber treatement and stuff. Know what worked? Dielectric Grease. Some guys on a corvette forum recommended it and it works great. I tried everything else, silicone grease, spray grease, the Pleger stuff or whatever, but good old dielectric grease has worked perfectly.
Reply 0
Oct 17, 2019 | 03:00 PM
Thanks for the heads up. I will give that a try. Also looking at sound deadening stuff because I hear this whine from the rear dif area. Directly correlated to speed. Oh well, google says it seems to be fairly common.
How do you apply it? Just smear it on and go?
Reply 0
Oct 17, 2019 | 04:45 PM
Quote: Thanks for the heads up. I will give that a try. Also looking at sound deadening stuff because I hear this whine from the rear dif area. Directly correlated to speed. Oh well, google says it seems to be fairly common.
yeah you just put a light film on. Remember you have the rubber seals, then the outside weather strip, and also do the the rubber seal where it meets against the c pillar too, that made a big difference on mine. It is completely silent now.
for sound deadening stuff check Raamat. You may want to confirm with the dealership that the diff sound is normal, on my C400 I had to have a rear diff o-ring replaced.
Reply 0
Oct 17, 2019 | 05:13 PM
The car is outside of warranty. Wonder how much they would charge to inspect it lol
The whine sounds slightly like an electric drill that slowly gets a little louder with more and more speed. It paces speed though for sure.
People riding in the car say it sounds like my car is electric o something
Reply 0
Oct 17, 2019 | 06:29 PM
Quote: The car is outside of warranty. Wonder how much they would charge to inspect it lol
that is not normal at all and I would take it to the dealership or independent shop ASAP and probably not even drive it.
Reply 0
Oct 17, 2019 | 06:36 PM
Quote: that is not normal at all and I would take it to the dealership or independent shop ASAP and probably not even drive it.
this is the noise
Reply 0
Oct 17, 2019 | 07:10 PM
Sounds like a wheel bearing in its way out to me.
Reply 0
Explore
Oct 17, 2019 | 09:03 PM
Quote: Sounds like a wheel bearing in its way out to me.
drove it with buddy in the car. Sounds like differential. The car is 2 months out of warranty. Ughhhhh
Reply 0
Subscribe
Currently Active Users (1)
