HELP, how to remove the rear seat cover
Old Dec 15, 2020 | 05:55 PM
pablitoito's Avatar
MERCEDES CLASE C 220 W205
Hello, let's see who can help me, I want to remove the rear seat cover, does anyone know how to do it? I mean this
https://ibb.co/qn9zzbm
I have seen some video that is removed with a special tool, but can it be done in another way without that special tool?
a greeting
Old Dec 15, 2020 | 08:24 PM
shan16's Avatar
C250
a greeting
ru planing to remove cos of ambient light? If so you don't need to do that
Old Dec 16, 2020 | 03:44 AM
pablitoito's Avatar
Hello friend, I do not want to remove the ambient light, what I want is to change its cable, my cable is three-color led and I want to change to 64, and the connection is inside, and the cable goes up inside, how do I do it?
Old Dec 16, 2020 | 10:17 AM
Cilo C Class's Avatar
16 C300 W205
Pablitoito,
I just installed this rear strip ambient light on my car (see photo) I agree with Shan16 above, you don't need to remove seat cover. As far as special tool, I just used my trim tools (see photo below) to pry the opening wide enough to slip in the wiring. I would imagine to repeat that process in reverse to remove wiring. Is the photo in the link you provided a photo of your car ? if so, I don't see what you're asking since I don't see anything there to remove. If not, then perhaps you could take a pic of your car. Anyways, here to help if you have any questions.
trim removal tools
to pry the opening wide enough to slip in the wiring. I would imagine to repeat that process in reverse to remove wiring. Is the photo in the link you provided a photo of your car ? if so, I don't see what you're asking since I don't see anything there to remove. Anyways, here to help if you have any questions.
rear ambient strip
Old Dec 16, 2020 | 05:39 PM
shan16's Avatar
C250
Originally Posted by Cilo C Class
Pablitoito,
trim removal tools
rear ambient strip
which seller did you buy your ambient from? There are so bright mines not that bright which i wanted it and my setting set on 5 still not bright enough
Old Dec 16, 2020 | 06:15 PM
pablitoito's Avatar
Hello, thank you very much for your help, that's what I want, but I throw it away and it doesn't open much, I'm afraid of breaking it.
They installed it but now I want to do it myself and change the cable.
Where did you upload it? How did you get it to the back of the center console?
https://ibb.co/RpZPhHR
I see that the cable goes under the seat and goes upwards but I see it complicated, how did you do it?
Tomorrow I send photos of mine.
Old Dec 16, 2020 | 07:22 PM
16 C300 W205
Hey brother, I was terrified of the thought of doing this at first, but so glad I went ahead with it. I installed the kit after I saw a tutorial on YouTube from this guy I follow called Flexx Alexander. Not sure if you've heard or him or not but he's done a ton of mod videos on his W205 and recently did a 5-Part Ambient Light segment on his channel. The Rear Seat Ambient strip lights was part #5 of that series. You should go check him and his videos out . They answer all of your questions. Oh and the kit he uses in video is from a company in Asia called DMP car design. Flexx provides links in his videos of how to purchase. Lastly, go for it young man.
Old Dec 16, 2020 | 08:19 PM
shan16's Avatar
C250
thanks yea dmp car design there have reseller in Australia aswell
Old Dec 17, 2020 | 07:12 PM
pablitoito's Avatar
Hello friend, if I have seen him I know him but it is not very clear what he does with the cables, where he leads them and where he passes them, so I ask here
Old Dec 18, 2020 | 08:39 AM
16 C300 W205
Hello friend,
Okay so, I am not 100% sure I understand your question. I don't think you can swap out one piece from one ambient kit and connect it to another but you might. If your question is how do you power it up, Well there are two ways that I know of. One way is to connect it direct to the main harness kit most likely stored above your drivers side footwell light and the other is to connect it to the rear turbine vents provided you already did that install. If you are wiring it up direct to the main harness you simply just run the wire along the center arm console and continue on to the main harness (see photo). If you've previously installed the rear turbine vents, you could connect it to that since there is already power running to the harness. My Rear Seat Ambient Strip wiring harness from DMP came with splitters built in so it connecting it to the rear vents was straight forward as easy as plug and play. Why dont you try texting your question to DMP Car design on WhatsApp to +60 17-607 1426. Just be advised of the time difference (located in Asia)
run wire under this panel from side of rear seat to front of car to the main harness
Last edited by Cilo C Class; Dec 18, 2020 at 09:12 AM. Reason: re-read your question.
Old Dec 18, 2020 | 04:45 PM
pablitoito's Avatar
Hello friend,
Thank you very much friend, it is currently connected to the rear vents and what I want is to change the 3 color cable for 64.
The problem is, I don't know how to run the cable from inside the seat (take it out from below) from the LEDs to the rear air vents.
I don't know how to get from the seat to the rear center console vents.
How do I go from point 1 to 2?
https://ibb.co/qsnnN70
https://ibb.co/WKcBVCD
I don't know what you mean by dividers.
Old Dec 18, 2020 | 07:35 PM
16 C300 W205
Amigo, as you can see in the attached photos the wire from the Ambient Strip can clearly be seen. I meant to cover them with black electric tape but glad I didn't so you can see them. Once you remove the rear vent cover you can connect them to the rear turbine for power quite easily. send me a private message if you have additional questions.
wire from Rear seat ambient light (drivers side)
wire from rear ambient strip light (Pass side )
Old Dec 19, 2020 | 03:29 PM
shan16's Avatar
C250
And if is hard for you then goto dealership ask them to remove the seat back cover there will do that for you. There might even do it for free as is only few minutes job
Old Dec 19, 2020 | 06:19 PM
pablitoito's Avatar
here at my dealer they charge me, do you know how to remove it?
Old Dec 22, 2020 | 02:44 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Pablitoito,
trim removal tools
rear ambient strip
OMG! I thought I was obsessed with ambient
Old Dec 22, 2020 | 06:00 PM
16 C300 W205
[QUOTE=benzdude;8230497]OMG! I thought I was obsessed with ambient [/
No I’m not. I swear. No ****. Ask my mother lol
