Duralast Platinum AGM Battery H7-AGM Group Size 94R 850 CCA. ANy Good?
Duracell Ultra Platinum AGM BCI Group 94R Car and Truck Battery
SLI94RAGM
I got 10% ($22) off and $10 rebate, plus another $10 wen I return the core to batteries plus.
Thanks @mikec35
My ambient lights no longer flicker went starting. Hopefully, it also fixes the issue where audio cuts for a quick second went start/stop starts the car. (it didn't happen all the time but...)
I think it was my JL Fix 82, which has a 10 volt as minimum voltage requirement. Starting voltage would go down to 9.4volts on old battery.
Luckily my Helix V Twelve DSP can handle down to 6 volts.
Thanks @mikec35
When start/stop shuts of the engine (with music playing) the battery was having a hard time staying over 10.5 volts.
I guess my JL Audio fix 82 was losing power for a second while the car cranks. I monitored the voltage and lowest voltage drop was to 9.4 at restart.
Everything seems fine now. Still test driving. I also got a new voltage regulator just in case.
Not really worried, as the JL Fix 82 and OEM amp will be replaced by a Nav-TV Zen-M soon.
Less load on the battery.
