New Ultra-Thin Android 13 12.3" Screen Snapdragon 685 8-core 8GB RAM 128GB ROM
Old Sep 4, 2025 | 04:05 AM
  #101
Pajinuk's Avatar
C300de C Class W205 2020
Originally Posted by benzdude
Yes, very happy with it. The current software has a few minor issues, but it works great overall.
This has wireless/wired Carplay and Android Auto. I just use OEM Bluetooth + Shanling M6 Ultra (or phone) + Tidal for music.
I also removed the OEM amplifier and added a NAV TV Zen-M + Audiotec Fischer HELIX V TWELVE DSP. Sounds Great.
Morning, really interesting, progress, have you any audio records with same song before and after? I cant believe that just stronger hw can impact on improving the audio sides. Thank you. Sono more burmester now after replacing the amplifier?
Old Sep 11, 2025 | 08:27 PM
  #102
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by aznmode
Is it sleeping properly now? When are you gonna get the cluster? This screen should be able to mirror on to the cluster.
I haven't seen any battery drain issues with the sleep cycle. If you get the USB dongle + apk mentioned in my previous posts, any screen can mirror to the cluster.
Old Sep 21, 2025 | 05:00 AM
  #103
aznmode's Avatar
2010 c300
Does anyone make another bracket that will move the screen closer to the dashboard like Oem screen?
Old Sep 21, 2025 | 08:04 AM
  #104
Pajinuk's Avatar
mine is closer how original
Old Sep 22, 2025 | 01:30 AM
  #105
aznmode's Avatar
2010 c300
Is this Snapdragon 685?
Old Sep 22, 2025 | 02:16 AM
  #106
Pajinuk's Avatar
622 is old screen but yes today is 685 I think
Old Sep 23, 2025 | 01:25 AM
  #107
aznmode's Avatar
2010 c300
Did you have to pay custom fee?
Old Oct 18, 2025 | 02:40 PM
  #108
aznmode's Avatar
2010 c300
Just got mine from cheerdriving and is a YH S618 also. Just did I fit test for now. It is a bit too big for my taste but I think if it sat closer to the dash it wouldn't look so bad. Then i would be able to live with it. But right now it looks unsightly.
Old Oct 18, 2025 | 02:48 PM
  #109
benzdude's Avatar
Top Answer: 1
Well, at least she won't complain it's too small anymore. 😆
Old Oct 19, 2025 | 02:03 AM
  #110
aznmode's Avatar
2010 c300
I dont get my command display
but when I adjust fan I see the temp pop up temporarily. Tried all thr display settings.
Old Oct 19, 2025 | 02:19 AM
  #111
aznmode's Avatar
2010 c300
Figured it out. Found a video to reset command by holding down command eject.
Old Oct 19, 2025 | 03:35 AM
  #112
aznmode's Avatar
2010 c300
Deleted
Old Oct 19, 2025 | 04:41 AM
  #113
aznmode's Avatar
2010 c300
Wow lol. I accidentally pressed the screen off button next to wheel command
Old Oct 19, 2025 | 05:05 AM
  #114
aznmode's Avatar
2010 c300
Turns out I have a Harman unit so no audio lag for me watching YouTube. But I've yet to test audio quality. Will compare YouTube music via BT tomorrow.
Old Oct 19, 2025 | 05:09 AM
  #115
aznmode's Avatar
2010 c300
Anyone know what clock connector is for?
did you ever figure this out?
Old Oct 20, 2025 | 12:56 PM
  #116
aznmode's Avatar
2010 c300
Originally Posted by sleepings
To be honest with you I kind of regret buying this. The only thing this is good for is the access to newest navigation.
Very frequently my USB flash drive that I use for music just randomly stops working and continues after 2-3 minutes. Tried with multiple flash drives and still the same.
Sometimes when I start the car it takes the screen 2-3 minutes to start playing the music from the flash drive. I can see the song on the screen but the sound takes a lot of time till it starts.
The anti-glare on the screen is absolutely awful. On sunny days, I can hardly see anything on the screen from the driver's POV.
The heat that comes from this thing is a lot.
It most definitely drains a bit from the battery because sometimes I noticed that I turned off the car for a couple of hours, come back and once i put the key in the car the screen immediately starts without any loading.
and more
I have to agree on the non existent anti glare. Not only that but even set to 100% brightness it is still not birght enough to battle glare. Anyone know if putting anti glare screen protector will help?
Old Oct 20, 2025 | 01:27 PM
  #117
benzdude's Avatar
Top Answer: 1
Sorry, no. Please ask yeehung or the seller.
Old Oct 20, 2025 | 01:32 PM
  #118
benzdude's Avatar
Top Answer: 1
Weird, I don't think mine has that hazy issue.
One thing I had to do is toggle the "automatic brightness" option in the factory settings so that screen does not dim in daytime vs night time.
See #16 in the yeehung FAQ video, #2 post.
Old Oct 21, 2025 | 02:28 PM
  #119
aznmode's Avatar
2010 c300
I will check thank you. I also downlaoded the KSW toolkit 3 ($15.99 for license) but my brightness is already set to max. The haze is from the film I have not removed since it is acting more like a matte effect. Less sharp reflection vs without the film. I think overall its just not bright. But most of thr time when there is no glare it it looks great. I am getting a samsung anti glare protector to see how it goes.
Have you played with the took kit? If so your thoughts?
Link
https://play.google.com/store/apps/d...le.ksw_toolkit
Old Oct 21, 2025 | 02:30 PM
  #120
benzdude's Avatar
Top Answer: 1
Link
First time hearing about a toolkit
Old Oct 21, 2025 | 02:33 PM
  #121
aznmode's Avatar
2010 c300
By the way do you have 8.4 original screen and have this issue? The ntg screen is a shrunk side ways or is stretched tall. My EQ knobs are oval and my radio icons are rectangular not square.
Old Oct 22, 2025 | 05:38 PM
  #122
aznmode's Avatar
2010 c300
I just found out this unit has the aux in already wired up. So you dont need to do the back of unit hack. This is not the same as usb aux. There is a 3.5mm female connector on the quad lock harness it comes with. Disconnect the 3.5 headset cable from the usb aux box and plug it directly to this input. Change media source to aux.
Now you do have to have aux input enabled through coding either local or remotely. Or buy a aux input enabler on amazon or mbito.
On another note. Upon comparing I learned the usb aux left and right are actually reversed using that youtube test. Aux input is correct and definitely sound better. Also if you have audio lag watching video this will eliminate that. I never had issue since my unit is by Harmon. Only Panasonic ones have lag. So you also no longer need to buy the DSP box from your seller.
Old Oct 25, 2025 | 03:02 AM
  #123
aznmode's Avatar
2010 c300
1. OEM music still the same. Android Auto (Tidal) is similar quality as oem, due to newer USB box.
2. You can put the GPS antenna anywhere you want, but it must have a clear view of the sky. Mine is on passenger side top corner. I used a wire guide with a rope to thread the cable behind the glove box. Then up and under the rubber door trim. Easy.
3. No. Those OEM USB ports have different uses for the head unit. Plus you need one oem USB port for Android audio input.
here is where i put my gps so I didnt have to run wires in the dash.
Old Oct 25, 2025 | 03:18 AM
  #124
aznmode's Avatar
2010 c300
Using Samsing screen protector for s11 ultra tablet. Cut to size. Its a little bit more bearable in situation when the sun hits my seat. Wish it could be better. But its not always like this so I can live with it for now. I may try a matte screen protector next time.
Without sun hitting my seat its very readable
Old Oct 25, 2025 | 02:21 PM
  #125
aznmode's Avatar
2010 c300
How to prevent zlink from auto connecting and taking out your wifi.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
