paint protection in front of rear wheels
thanks.
I wouldn't recommend removing them unless you want stone chips where they were. After all, how much of the front tire is exposed at the bottom of the fender? You know it's throwing stones right at the quarter panel....
i have had mud shoot up on that segment. if you look at the car, its fatter there, and therefore the protection.
the testing must have yielded some chips to warrant the paint protection.....
I didn't engineer it, so back off. They put it there for a reason. If you don't want it on your car pull it off then.
How far back should I go?
Automakers put these films on the sections of cars that angle outwards infront of the rear wheel in order to protect the paint. Cars like the W211 dont need it because there really is no outward angled section. The cls has more of an angle around the rear door so they have the film there to protect the paint.
A car like a 996 Turbo or any wide body porsche really needs the protection because that pannel is subjected to some serious rock spray.
If you look a the paint on the lower rockers right behind the wheel, you can see a pattern that matches the tire tread becasue the tread throws rocks rewards. If the rocks are hitting the pannel directly behind the wheel its a safe assumption to say that the rocks could fly rewards and hit any outward jutting body pannel.
I know it looks like junk and they always yellow. If I had a CLS I think I would take the factory film off and put on a layer of 3M rock protection instead. The 3M is far thinnner and it is hard to notice.
I do see both sides to the debate though...
http://www.xpel.com/products/configu...=26&model=1164
