Check Engine Light On-Car in the Shop
Any ideas? Thanks!
Any ideas? Thanks!
TRy to think what could have caused it.
Could be bad fuel issue...
This is very sudden as the car runs normal till today. I always warm up the car before drive off. It must be those dame Costco gas!
The dealer should call back in couple hours. I'll wait and see what they have to said. Anyone else had similar issues?
Dealer says the car should be ready to go by end of tomorrow. Thanks guys.
Oh yeah, I think my car is the first to roll off the assembly with Sep 27, 2006 production date and in service Dec 13, 2006.
Regarding Costco.....not going there anymore. Will stick to Shell from now on just in case.
First and formost, purchase all fuel from new gas stations due to issues with sediment in the underground tanks and crap/water in the lines. The newer the better.
Costco is very aggresive on their fuel filtation filters by changing them out when due. Not like some gas stations that need to save $$ by using them past their useful life.
As far as the 91 rating, if it was less than 91, you and your beastly car would be the first to know that.
please give more info on this ground fuel thing you were talking about please
Same thing -- car was on for 10 min then stopped at grocery store so it was warmed.
My searches showed that it's esp a prob if car is warm. No idea. Can't believe so many people have this problem. WTF. Find a new crank sensor supplier!!
Thanks for the information m_berman. This makes me feel better because I have been using Costco gas from day 1. My mechanic didn't say anything to me, so I think you are referring to mbenz1's mechanic.
Since we are on the subject of gasoline, which brand do you guys use? Any noticeable differences between Costo, Shell, Chevron, 76 and Valero?
The higher the octane the better engine performance. At speciality gas stations they have available 100 and 110 octance gas. I have used 100 in my CLS 55 and it feels like it is a CLS 65!
It's a matter of time until somehow you get water into your gas due to some gas station's underground storage tank leaks. When it happens, you need to visit the dealer to have the fuel system cleaned and fuel filter replaced. It can damage fuel injectors and sensing devices. If that happens, return to the offending gas station and demand restution of the $$ spent at the dealer for repairs. In Kwait, you're on your own.
I dont think the states have anyone that goes around to check?
You will be good to go.Failed cps can't show proper crank speed and that is what tells the ecu when to fire the spark.That and the cam position sensor
Which with any luck won't fail for a long time
ohlord
