No error indication when SC shutsdown?
Old Feb 2, 2010 | 08:15 PM
RRnelcheeze's Avatar
CLS55
I have read about this a little bit here, so thought i would share my experience. Supercharger shutdown on me today, after a good high speed run. It does feel like you loose 150hp, thought I was in my E320! Engine revving in the 6's but no power! I was looking for an error or warning on the dash, but none. After a few miles of driving normally It kicked back in. I'm on a replaced but stock IC pump.
Is no warning on the dash normal?
Is the SC bypass a normal thing after a good long WOT run?
Old Feb 2, 2010 | 08:27 PM
320 dreamer's Avatar
2003 porsche 996 turbo
no cels are normal. no s/c shutdown isnt normal after a long run unless the oat's get to high.
Old Feb 2, 2010 | 09:03 PM
dacls63amg's Avatar
2008 CLS63 AMG
Ive been hearing this a lot by other members whos s/c just shut down over long periods of WOT.
Old Feb 2, 2010 | 09:42 PM
CLS55
I was WOT for a bit.
Old Feb 2, 2010 | 10:53 PM
dacls63amg's Avatar
2008 CLS63 AMG
I know with the 55 motors. At start up when the engine is cold the s/c kicks on to help warm up the car faster. And at WOT for a while the computer will read the high temp and shut down the s/c for a lil. Its just a safety mechanism from MB so the engine doesn't blow. Have you taken your car to the dealer to see if there are any faulty codes? In my 63 when Im at WOT for a long time. Then stop and stomp on the gas again it feels much slower. I believe its just due to the engine being heat soaked. I know the 55's also get heat soaked fast. Maybe a upgraded HE and a better pump would help with this.
Old Feb 3, 2010 | 12:40 AM
Roseylv's Avatar
w212 E63 / 996tt
This is pretty normal for the 55k motor. I had an e55 for 3 years and now a CLS55. My supercharger shut down on me while my E55 was stock. There has been a lot of talk about this if you do a search. I then installed the Johnson pump cm30. After the johnson pump was installed, I also had a bigger pulley and ecu tune + headers and it never shut down on me, even w/ the mods.
I have a bigger heat exchanger and pump on order from Eurocharged for my CLS.
For the record, I have had a lot of issues with mercedes service saying they can't duplicate the problem. In the end, I said screw it. I'm not going to argue with them so I just pulled the trigger on the pump. In practice, my supercharger only shut down when I was doing canyon driving and holding gears in manual mode.
In short, just get a Johnson pump and be done with it.
Old Feb 3, 2010 | 01:57 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
its a common problem on the 55k motor. if u still have warranty on the car just bring it in and have them check and then replace the oem bosch cooling pump and that will solve your problems. if you are out of warranty then go buy yourself a johnson CM30 pump and have that installed. (150-200)
Old Feb 3, 2010 | 06:38 PM
CLS55
Thanks all. Its still under warrantee but I know that i have the stock IC pump which was replaced one time, and do plan to upgrade the cooling capacity. Saving up for the evosport - Kompressor Cooling Upgrade, since they are pretty close to me, kinda pricey though.
http://www.evosport.com/product/prod...ER.M5K.PPC.211
Old Feb 3, 2010 | 07:52 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
u can find a better HE upgrade for much less than what they charge over there.
do some research on the board and u will fin loads of useful info.
heres my old thread on some of the stuff that i found.
https://mbworld.org/forums/w211-amg/...questions.html
Old Feb 3, 2010 | 09:12 PM
CLS55
Wow that is a much larger one, pretty sweet, was that DIY?
Old Feb 3, 2010 | 09:21 PM
Roseylv's Avatar
w212 E63 / 996tt
The evosport cooling option is In addition to the stock H/E not a substitue. According to Evosport, the bigger H/E will not do much more than circulate more hot water than stock. I don't know what to think.
All i know is that I went with the cheaper option and purchased a bigger H/E and Johnson pump. awaiting delivery from Eurocharged
Old Feb 3, 2010 | 09:22 PM
Roseylv's Avatar
w212 E63 / 996tt
The evosport cooling option is In addition to the stock H/E not a substitute. According to Evosport, the bigger H/E will not do much more than circulate more hot water than stock. I don't know what to think.
