20 Horsepower.com
Old Aug 23, 2005 | 06:13 PM
smjjpres's Avatar
ML 500
20 Horsepower.com
Is this a total and complete bunch of crap? For $19.95, I certainly think so.
Anybody with technical info. that I don't have? Common sense tells me it is junk.
http://www.20horsepower.com
SM
Old Aug 23, 2005 | 06:47 PM
Kenzmbz's Avatar
SM
i will buy 10 for an increase power of 200hp!!! And next week when i get my paycheck i will buy 10 more !! SL65 beware
Old Aug 23, 2005 | 06:51 PM
trust203's Avatar
I believe there is a resistor inside that little box, it conect to your wire between the airflow meter and ECU. It try to fool the ECU to give more or less fuel by useing the resistor to change the current. For example the ECU think the engine need more fuel due to the current change by the resistor. But actually the airflow is not change at all ! Just don't take the risk it may mess up your engine, due to the difference of every car's fuel management.
Old Aug 23, 2005 | 08:52 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
run, don't walk, run from this snake oil.
Old Aug 23, 2005 | 09:02 PM
respdoc's Avatar
CLS
Besides being total even they didn't list Mercedes as a vehicle this would work on.....so why did you bother to post it here?
Old Aug 23, 2005 | 10:34 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
For $30, I'm curious. Maybe I'll put it on my ex-wife's car, it's a listed application!
Old Aug 23, 2005 | 10:47 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
hahahaha ... enough said.
Old Aug 23, 2005 | 11:01 PM
Vomit's Avatar
2002 C32 Black/Charcoal
You guys got ripped off. I went to www.25horsepowerand2inches.com, where I got more H.P. and a kompressor-powered kockpump which plugs into my C32 cigarette lighter and features 19 lbs. of boost. So, if you see a guy "tooling" around San Diego with a grimace on his face, peek on in the driver-side window and check it out! I might even let you TRY it out.
