Adding a subwoofer to W203 C32 Comand
Old Aug 31, 2005 | 04:39 PM
bubbenzo's Avatar
BMW 535i Turbo, E36 M3
I've searched for this, because I know it has been discussed, but all of the threads I have seen didn't really give me the answers I was looking for. I basically want to put one 12" subwoofer in the spare tire "hole." How would I go about wiring the amplifer remote lead? How would I cut into the speaker lines to supply the signal for the subwoofer? I basically want to keep the stock speakers and amp for now, I just want to add a nice amp/sub combo for some extra thump.
Thanks in advance.
Old Sep 1, 2005 | 04:24 PM
bubbenzo's Avatar
Anyone?
Maybe I would get more response in the C32 forum. Will a moderator move this please?
Old Sep 1, 2005 | 05:57 PM
bubbenzo's Avatar
Thank you for moving this, John.
Old Sep 2, 2005 | 12:16 PM
360_iti's Avatar
W203, W211, W219, W212
no one really knows a simple way to do this. issues with fiber optic. some people did it, but it took quite a bit of effort and $
Old Sep 2, 2005 | 07:08 PM
benzmodz's Avatar
W203 slightly modified
Disconnect the woofer in the rear parcel shelf and use that line as a speaker level input.
Old Sep 4, 2005 | 05:30 PM
360_iti's Avatar
Is it really that easy? I thought it was more involved than that.
What's the output of the stock power amp ?
Old Sep 9, 2005 | 01:34 PM
c43-e55's Avatar
just unplug the rear deck speaker/sub use a hi-lo converter and u get rca out puts
Old Sep 9, 2005 | 01:36 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
I just tapped off of the speaker wires and used a line converter. The converter cost $30 or something and is really easy to use. It has nothing to do with the F/O of the car when working on adding a sub.
You can wire your remote lead to a keyed power source so the amp turns on when you start the car.
Old Sep 13, 2005 | 10:28 AM
360_iti's Avatar
Based on your comments I'm assuming that you disconnected and left the stock SW in place and install a new one somewhere else, true ?
I was wondering if there is an easy way to reuse the existing slot since I don't like having a box in my trunk. The stock SW looks really thin tho.. maybe thats why it sounds so crappy.
