Rear Rotors...
Old Jul 11, 2002 | 03:36 PM
Boo2's Avatar
C32 AMG
Rear Rotors...
Anyone ever considering changing the rear rotors to match the front cross-drilled ones?
Old Jul 12, 2002 | 10:14 AM
jswedberg's Avatar
C32 AMG
Do you mean cross-drilling them? Or actually replacing the rotors with ones like on the front?
I think it would seriously upset brake balance. Not to mention it would take some serious engineering to get the cailpers to work, or to replace out the rear calipers.
I'd be careful drilling the rotors, too - unless it is done very carefully microfractures will occur. That would be bad.
Old Jul 12, 2002 | 10:24 AM
JamE55's Avatar
Out Of Control!
Re: Rear Rotors...
If you're looking to replace them you can probably try www.irotors.com
Old Jul 12, 2002 | 10:56 AM
Boo2's Avatar
C32 AMG
JamE55 - How do you think these compare to Brembos?
jswedberg - Naw man, i'll replace everything rotors and matching calipers (not AMG tho cuz I don't think they make them). These are your brakes, you don't want to go cheap on them (well, you don't want to go cheap on anything either).
Old Jul 12, 2002 | 02:12 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
replacing the rotors wouldnt upset the brake balance at all. it would keep the rotors cooler and look better no doubt! I saw a Cl the other day with Brembo brakes on it with high gloss black calipers. It looked SOOO good.
Old Jul 12, 2002 | 07:11 PM
JamE55's Avatar
Out Of Control!
Not really sure about these but i've been talking to some people at Brembo and this stuff is top notch! If you really love your car get these and you won't be sorry!
Old Jul 13, 2002 | 04:56 PM
JustinTRW's Avatar
C32 AMG
If you take off your caliper and look on the other side, it says BREMBO on it, despite AMG being painted on the front.
Old Jul 14, 2002 | 03:39 AM
Mach430's Avatar
The C32 brake calipers are made by Brembo, and are very good for stock brakes. However, they do not compare to the 13.1" or 14" kits offered by Brembo. These kits use an entirely different caliper, about twice the size (length and width), originally designed for the Ferrari F50. Trust me, once you go with a Brembo Big Brake Kit, nothing else is the same.
Old Jul 14, 2002 | 02:36 PM
JustinTRW's Avatar
C32 AMG
Mach,
Know if they reduce unsprung weight?
Old Jul 15, 2002 | 11:10 AM
Boo2's Avatar
C32 AMG
Mach,
Is the big brake kit for both front and rear brakes? I'm only interested in the rear rotors/calipers.
Old Jul 15, 2002 | 11:34 AM
JamE55's Avatar
Out Of Control!
Mach,
Big Brake kit is only for the fronts.
Old Jul 15, 2002 | 01:10 PM
Mach430's Avatar
We can have Brembo make a rear kit, fitted and tested, for your car. The question is, would you want it to be designed for your stock front calipers or for the big 14" kit?
Ben
Old Jul 15, 2002 | 03:59 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
any1 know when someone will have cross drills for W210 E55 front and rear for the OEM Calipers? Thanks.
