20x10 & 20x9 Wheels on C55?
I want to install 20x10 and 20x9 wheels on my 2006 C55.
Does anyone know if they will fit without modifications to suspension or fenders?
I know most of you have installed 19"s but I want to take it to the max.
Would I have to cut the fenders? What is the correct bolt pattern (5 x 112)?
What is the correct offset 38, 37 or 35? Would a 3.79, or 3.75 lip create a problem?
You're right about the bolt pattern but I'm not sure about the offsets.
IMO, I can't imagine 20's looking very good on a c class
Try to keep 2 words in mind... Form and Function
BTW, saw your car at the LA Autoshow. Lookin' good. Too bad nobody was there to pop the hood.
1) 20's just look TOO big on this car. It's not an SUV.
2) I would challenge if you would really get better performance from the tire. 285 vs 275? Not sure if it's going to make a huge difference. In fact, even if it were a better patch, the wheel weight would definately offset the tire advantage. Plus, It's harder to find performance wheels that size.
3) I'm sure the ride quality will suffer quite a bit. Assuming you're going to keep the same stock diameter, you either run stock 225/40/18, 19x10 w 275/30, or 20x10 w 285/25.
225/40/18 25.08" diameter, 3.54" sidewall
275/30/19 25.49" diameter, 3.24" sidewall
285/25/20 25.61" diameter, 2.80" sidewall
Do you really want to go with that thin of a sidewall? Pretty harsh ride I'd imagine. The 275/30/19 seems like a more reasonable combo.
Basically anything above 19's on any performance car is pointless and boarderling ghettofab.
My fav wheel is the Brabus V1 19's for AMGs, but these HRE fanbois will say different, becuase of cost and the weight of German Tuner Wheels.
I was shopping the Brabus and HRE's as well but will consider what other forum members an offer. i want to be thorough as possible. I know wheels are a personal preference but there is something to be said about consensus opinions.
