any C320 or C350 with supercharger?
Old Apr 13, 2006 | 03:44 PM
Substance's Avatar
i assume C320 with a supercharger would be like a C32 with manual tranny, however a C350 with the same configuration would be much better , possibly better than a C55.
Anyone tried this? C350 for 38000 then a superchager for 13000(kleemann), some suspensian and brake upgrades and you pay nearly 60k which is also equals to a brandnew C55. Probably much higher Hp and torque and a manual tranny. what do you guys think?
C320 stock 215hp pluss a supercharger you get 350hp
C350 stock 268hp with the same math around 400 hp
Old Apr 13, 2006 | 04:42 PM
TopGun32's Avatar
the Kleeman set up for the 3.2 is 330hp
the 3.5L does not have supercharger yet, but I believe its almost out or due to be out.
I agree, the 3.5L will get around 400hp, but remember the internals are not made to take boost. Also, the transmission does not like too much torque. If they make a kompressor, it will be a mild boost type. Maybe 4, 5 or 6 lbs of boost.
The current C350 7sp transmission is not be the AMG version that will be put on the E63. It will be similar, but probably lacking the programming and the additional strengh to take more torque.
I wrote about this a few months back. It would be a nice sleeper to do this. Plus you can get a manual transmission if you wanted. However it will take too much work and too much money to get it to par to AMG quality.
by the the way, the 3.2 C32 engine and the 3.2 C320 may share the block, but its internal components are not the same.
The 3.2 can take boost and additional boost will not be a problem. In stock form, the C32 produces close to 12lbs, with Ecu/pullies about 14 to 15lbs. That shows you that the engine is built like a TANK.
Its a good idea... but one that not many people will do.
Old Apr 13, 2006 | 09:32 PM
BimmerBeater's Avatar
Would it be possible to hook-up a supercharger psi output controller to the w203; adding psi beyond 15? I know guys with turbos have E-Manage and gagets like that.. but i've never heard of anyone with superchargers using them...? I could easily see the C32 putting >400rwhp with more than 15psi.
Old Apr 13, 2006 | 10:08 PM
Eurocharged Rick's Avatar
SPONSOR
if you are talking about a boost controller, then no...superchargers work with pulleys, not exhuast pressure like turbos...
but, i do think it is possible to put out more than 15psi...i thought the factory rating was 14.7psi or 1BAR...so increasing this should yeild about 18 or 19psi...
does anyone have a boost gauge on the C32 yet? i was going to put one on, but i ended up selling it with the HUD unit from my old car...i am going to get another one, just haven't had the chance to yet...
Old Apr 14, 2006 | 02:57 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
with the pulley and ecu C32 runs with 21psi or something close.
Old Apr 14, 2006 | 05:44 AM
N.M.M.'s Avatar
stock the C32 runs around 14psi, With the pulley it runs around 18psi.
Old Apr 14, 2006 | 12:25 PM
BenzoAMGpower's Avatar
Cars and boats!
my boost gauge reads 19psi peak but when weather dips below 50s, it reads 20psi peak.... observe...
http://media.putfile.com/C32-boost
Old Apr 14, 2006 | 01:37 PM
SPONSOR
what did it read on stock boost?
Old Apr 15, 2006 | 03:22 PM
Cars and boats!
dont know, i installed the gauge after i got the ECU and Pullys
Old Apr 16, 2006 | 04:33 PM
CynCarvin32's Avatar
Mercedes Benz
not quite Frank....
No tuner makes a pulley that creates 21 psi of boost. 15-17 is more like it.
All tuners have the same sized pulley and no one quote figures that high.
MB quotes 1 bar but they dont really make that much boost in real life.
Old Apr 17, 2006 | 12:54 PM
TopGun32's Avatar
wow.. 19Lbs... I didn't know.
i thought it was more like 15 to 16...
these engines can seriously take the boost.
Old Apr 17, 2006 | 10:34 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by CynCarvin32
not quite Frank....
i stand corrected Must be daydreaming when I typed that.
Old Apr 17, 2006 | 10:42 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
looking at your video makes me really want to do those mods in a hurry.
Old Oct 7, 2011 | 09:46 PM
hotcorner216's Avatar
2008 C350 Benz, GLA250 4matic
Ill be happy with anything over stock on my C350 :P. So any superchargers coming out for us? W204s?
Old Oct 8, 2011 | 12:22 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Contact Eurocharged, they turbo'd one before...
Link: Turbo C350-EUROCHARGED
Old Nov 28, 2011 | 12:08 PM
[quote=TopGun32;1558013]the Kleeman set up for the 3.2 is 330hp
quote]
WHERE IS IT!?!?!? I want it sooo bad lol
Old Nov 29, 2011 | 09:24 PM
MBfinatic's Avatar
e36 318i, 2004 sti
There has been some turbocharged C350's..
