More power
Old May 8, 2006 | 04:46 PM
Derrick9191's Avatar
Mercedes C32
More power
So I am very new to this site and also a very new proud owner of a 02 c32. I had a couple of questions to ask about alittle extra power. When I was reading some of the threads I see you guys talking about sl55 splitter. WHat is this and where could i get one. Also what about the resonator i see people talking about removing that. What will this do for me and how hard is it to do. Oh ya what will green filters do for me and where could i get them at.
Old May 8, 2006 | 05:17 PM
Fifth Ring's Avatar
C32 AMG
I'm not sure what the splitter is; although it may relate to the air intake.
I doubt that there is much you could do to gain HP, short of giving a tuner $5,000. The exhaust system seems fairly unrestricted (noisy) and I personally could not live with a noisier car on a day-to-day basis. I doubt that there would be much improvement by opening up the exhaust.
Unlike my old Audi (twin turbo 2.7T), nobody makes simple software tweeks to get more boost. I was able to add 60HP to my Audi with a $500 chip. There are no such upgrades for our cars. The good news is that they do not need it.
I've also got 18 months of warranty left, and I do not want to void it.
Old May 8, 2006 | 05:31 PM
bViC's Avatar
2002 c32 /////amg
im also curious as to what is the sl55 splitter, and what does it do?
Old May 8, 2006 | 05:35 PM
Mercedes C32
yo
I was looking at the thread that was started about posting drag slip times and Vomit here posted this
Vomit
Vehicle I drive: 2002 C32 Black/Charcoal
Posts: 1,227 12.8/112 (with 2.1 60 foot)
Evosport Pulleys/ECU
Toyo T-1s (stock size)
Optima Battery
Magnecor wires/Denso Iridium plugs
SL55 splitter
K&N filters
50% mix 100 octane
So i was wondering what it was.
Old May 8, 2006 | 10:51 PM
Eurocharged Rick's Avatar
SPONSOR
the SL55 Splitter is the intake from the SL55 that goes from the air boxes to the throttle body...it is a bigger intake for better flow
Resonator is located in your exhuast, removing it a replacing it with a straight pipe will give you better flow...
Green Filters are high-FLOW (hope you are catching on to that word by now) air filters....
Old May 9, 2006 | 12:35 AM
Vomit's Avatar
see below
Old May 9, 2006 | 12:40 AM
Vomit's Avatar
Must-do mods:
Replace stock battery with Optima (drops 33 lbs): $100.00
Remove resonator (drops 10 lbs, adds few HP, very little exhaust noise change: $50.00
Short of going with pulley and ECU (for $3,000), try wires, plugs, filters, and SL55 splitter (which is the intake air housing splitter behind and on top of the engine which connects the airboxes housing the filters). All those mods will run you less than $1,000.00, and should get you some good improvements.
Old May 9, 2006 | 12:48 AM
SPONSOR
Originally Posted by Vomit
Must-do mods:
do you remember what model optima battery you are running?
Old May 9, 2006 | 10:05 AM
Mercedes C32
Splitter
Thanks for all the advice. Also on that splitter do i need the full thing such as boxes and splitter or can i just get the splitter and get the same little bit of increase. Also if it is just the splitter where can you get that?
Old May 9, 2006 | 10:24 AM
Vomit's Avatar
35 or 35r, I don't remember which (get the one that maintains the post positioning of the stock battery). You can also go more aggressive. . . Optima makes batteries which would probably work which weigh 25 lbs. I chose the 35 because it is lighter than stock and still exceeds the specs of the stock battery. The only issue with the install is that the Optima is physically not nearly as long, which means that it would slide around in the battery box, unless you fill the void up with something (I cut a piece of an old Boogie Board and spray painted it black). Check out Batteriesplus.com, they have a lot of choices for replacement batteries.
Old May 9, 2006 | 10:27 AM
Vomit's Avatar
I had mine done by Evosport, so I am not sure exactly what is needed. There have been threads dealing with part numbers and everything. . . try a search. If you don't find anything, start a new thread "Anyone have part numbers/installation tips on SL55 splitter?"
Old May 9, 2006 | 12:25 PM
SPONSOR
FYI: if you order the SL55 Intake Splitter from evosport.com, it comes with the green filters....they don't tell you that on the website, i found that out after i called to find out why it was taking so long and they told me they were waiting on the green filters that were on back order...
Old May 9, 2006 | 12:27 PM
SPONSOR
thanks...i will check into it
Old May 9, 2006 | 12:52 PM
Mercedes C32
yo
yo 1fastc32 where are you at in houston. I am from katy. what color c32 do you have. maybe i have seen you around
Old May 9, 2006 | 02:19 PM
SPONSOR
silver C32...i live in friendswood
do you make it out to any of the car meets around houston?
Old May 9, 2006 | 02:22 PM
Mercedes C32
nah
No man this is my first c32 I have owned. So I have no idea about any of that stuff. Do you have any info about it.
Old May 9, 2006 | 02:38 PM
bViC's Avatar
2002 c32 /////amg
where can you get the sl55 splitter?
Old May 9, 2006 | 02:57 PM
sohc808's Avatar
2005 SRT-6
You can get the splitter from your local m-benz dealer or from evosport. If you go to the dealer ask for:
# 113-094-01-03 splitter
# 113-094-23-82 hose for splitter
# 113-094-24-82 Hose for splitter
Four hose clamps
Also Note: That this is Not a bolt on mod. As you will need to slit the hose going to the airboxes. If you order it from evosport you can just bolt it on, as they include hose adapters that fit over the stock airboxes.
Do a search under SL55 intake, and you will find alot more information. Part numbers for sl55 airboxes etc.. Good liuck
Old May 9, 2006 | 04:27 PM
SPONSOR
evosport.com if you want a direct bolt-on application...
Old May 9, 2006 | 04:32 PM
SPONSOR
well, i hang out with a lot of different groups around houston because of the different cars that i have owned over the years...here are the sites i have a membership on, you can go the appropriate section to find out about what is going on around houston:
houstonperformancedriving.com
evolutionm.net
srtforums.com
msprotege.com
i am currently hanging out mostly with the guys from HPD, because they are not single car specific and most of them are more mature, experienced drivers...if you want to become a member over there, just use me as a reference, i have the same screen name there...
