Supercharger always active?
Old Jun 24, 2006 | 01:19 AM
A///MG_Power's Avatar
2012 Mercedes C63 AMG
Unhappy Supercharger Problem?
During normal driving around town and on the freeway, is the supercharger always active? Lately, I've been experiencing a very noticeable lag in the performance of the car (03.5 C32). Especially noticeable on the freeway, it seems that sometimes, I can completely floor the throttle and it literally goes no where (or very very slowly). When I downshift, there is no noticeable difference either, as it just revs but doesnt go much faster. I did not notice this before, and around town power is great, on tap. It just seems that sometimes on the freeway the supercharger goes into some type of limp mode to conserve gas consumption? However, I'm skeptical as this is a performance car. I've tried it with ESP off and on, and sometimes it lags sometimes it doesn't and performs fine..real inconsistent. I brought the car to Autobahn motors in Redwood City, and they said the car is fine. I'm so confused. Can you guys help explain or suggest anything or is this normal C32 behavior? Thanks in advance guys, you've always been great help! :thumbsup:
A///mg_power
Old Jun 24, 2006 | 01:35 AM
Bif powell's Avatar
2002 c32
Concensus on this issues seems to be either intercool-pump or MAP failure. Someone more knowledgeable will chime in...good group here.
Old Jun 24, 2006 | 06:11 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
have the dealer check for faulty intercooler pump. next question.
Old Jun 24, 2006 | 01:18 PM
emax's Avatar
2004 E55
The SC does infact become disconected at idle and when you are cruising (HWY, low throttle). It seems it uses some sort of magnetic field to accomplish this. This helps conserve gas on the highway and even keep noise down at idle. However, this has no effect on the car's performance because as soon as gas is applied the SC almost instantly becomes active again. So sounds like you have another problem like the other members suggested.
Old Jun 24, 2006 | 09:44 PM
SSDaytona's Avatar
2003 C32 AMG
Correction...
Emax,
Actually, from what I have found the SC engages at 2900rpm, not as soon as the throttle is engaged.
George.
Old Jun 24, 2006 | 11:40 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the supercharger is engaged through a electromagnetic clutch when the heavy throttle is detected. At cruise speed the supercharger is not engaged.
Old Jun 25, 2006 | 01:23 AM
thanks for all your input, have any of you heard or experienced this problem yourself? i will probably bring the car in soon, if you guys have any more input please let me know.
Old Jun 25, 2006 | 03:39 PM
m444's Avatar
Audi C7.5 S6
Sounds like the intercooler pump problem, I recently had this problem.
When the engine is completely cold, there is plenty of power, till the supercharger heats up.
Drive around a little bit, under boost and the power goes away (like driving with a lawnmower engine).
If under warranty, have them check the Inlet air temp (IAT) after driving hard.
If the temp climbs excessively, then the Interccoler pump is the most likely suspect. Mine went out at 33k miles.
Old Jun 26, 2006 | 03:00 PM
This sounds like it could be the problem, as the car has a little over 30k miles. I will bring it to the dealer within the week and keep you guys posted. Thanks a bunch.
Old Jun 26, 2006 | 05:54 PM
SteveL's Avatar
C43, SLK32, CLK63 Black Series
Originally Posted by A///MG_Power
During normal driving around town and on the freeway, is the supercharger always active? A///mg_power
On an SLK32, which shouldn't be any different than the C32, the supercharger is always engaged over 2900 rpm. It is also engaged below 2900 rpm if the engine load is more than 44%. The supercharger is never engaged if the car is not moving no matter what the engine speed.
I'd love to know where they come up with the 44% number.
Old Jul 20, 2006 | 01:19 PM
You guys were right as i brought the car in to autobahn motors in redwood city and they said there was a faulty air cooler pump. They replaced it under warranty. Seems to be a problem under 03.5 C32's around 30k + miles. Thanks for the help guys :thumbsup:
