C32 Fellows: Need Help w/ Instrument Cluster
Background: 2002 C32 AMG with 72K miles bought in San Diego October 05, now in Houston, perfect everything except:
1. The lights on my instrument cluster (in the orange-yellow screen to be specific) are not working properly. The problem is when the car sits in hot weather. At night, the cluster shows everything without a problem. During the day, when I park somewhere outside, the cluster is like blurred... it has to be a malfunction related the heat b/c it only happens when the car is outside... anybody had the same issues? And yes, I already turn the knob to adjust the dimming and it's not that.
2. I have an extra set of OEM Bi-Xenon but I would like to check if everything works properly. Is there a place that I can take this in to make sure the next user will have no problems? They have been sitting in my garage for a while now.
I'll appreciate any feedback from you guys.
Regards - Carlos
Anyone had this fixed??
Anyone know if you can slap in an 04 or 05 instrument panel and it will just "work" or does the diffrent display require a diffrent computer or firmware upgrades..
One thing I noticed when I did get the panel replaced on the C230 is that it started doing some things diffrently..
1) it counted MPG by counting down from 27mpg on a cold start (before the panel replacement it started at 17 and counted up).
2) It would actually give me a "malfunction"/warning when the Sunroof was open and I turned off the car..
3) Window quick roll down worked but roll up didn't
4) Auto window roll up when pressing on recirulate air (instead of default get air from the outside) stopped working..
I don't know if those are all Star Diagnostic settings or if they were caused by a software change from the new panel.. But something to look for when you get your panels replaced.
Josh
Austin TX,
You can fix it by getting a new cluster. On the E-class it was an $1100 part. I'm sure its not cheap for the C32.
I found it online at one shop.
http://www.mbeugene.com INSTRUMENT CLUSTER, C240, C320, C32 $477.60
I still haven't decided if its worth the $500 for the part to be repaired/replaced.
What about a front sunshade as a future option? I'm sure it can be done...
Carlos
Carlos
Where did you read about the guy swapping out his cluster? I would love to investigate it further. If the plugs are the same then the IC swap could work.
Would love to have the C55 IC.
If that doesn't work, do a search for "sunman" in the W203 C Class forum. The conversion was done to a 03 C320. The IC is from a W209. Very nice mod...
Question: Did your SA's just say ok and install the new cluster? or was there a little coaxing involved?
