Just Ordered the Coolmist Command kit
Other than E55Cent (Mario) and Richard who else has installed this on their cars? Is it difficult? Was it effective? What brand did you choose and why?
more fun to just buy and install parts!
I also installed a air temp Autometer gauge to track the CoolingMist. With out the CoolingMist I was hitting 220F at full boost and with the CoolingMist I was at 150F and the temp dropped down very quick. I have the mister come one at 2psi and spray with progression.
The install can be a big pain and make sure the pump is lower than the tank and that you use a check valve so the supercharger doesn't full fluid from the tank.
Mario
Mario
Mario
It's been a while since we last chatted. Wanted to give you an update on my car. Mechtech is still having trouble installing the Coolmist kit. Jim told me that he had to order an electronic module for $80 in order to get an RPM reading. Does that make sense? You did not mention anything about needing this. They told me that they had to install the tank really low so your advice about placing the pump below the tank may be the reason for not getting an RPM reading. Do you agree?
Without too much info to go on, I would say it is to monitor the amount sprayed. There should be two inputs to the spray including "onset" and "amount". The onset would most likely be boost activated in your case. Ex. Preset boost hits = spray starts. As heat, airflow, and boost continue to rise you want a linear increase in the volume of spray to match the increases. Otherwise the system would be junk just spraying a preset volume throughout the RPM/boost range.
Aquamist has a nice system that uses boost as onset and injector pulse to regulate the mist volume to that of the fuel. This system looks very nice in terms of matching fuel/H20/air ratios preciesly. I think some systems can use the MAF for signaling as well.
.......I'm affraid to ask....but how is the car??
BTW like Wes asked, how is your car running? When do you want to race?
Mario
Mario
As for when we can meet to race, I'd say it's premature until I get my it dyno'd again. I should be picking up my car this Wed but it does feel alot faster with all the latest mods I've added.
Mario
I will witness another dyno tomorrow in SD and post the results here. Maybe it's time to RACE!
