Going to fab up my own intercooler reservoir...
Old Oct 3, 2006 | 07:34 PM
  #51
jgsx's Avatar
04 C32
Excellent!
Old Oct 4, 2006 | 04:31 AM
  #52
pshek's Avatar
2003 C-Class Sportcoupe
Originally Posted by 1FASTC32
UPDATE: i ordered a new heat exchanger and a seperate reservoir today, it should be here before the weekend...i ordered a LFP Dual Pass Heat Exchanger for a 03 Cobra(same dimensions as ours but more efficient) and an upgraded 03 Cobra reservoir with a 4" Fuel Door so that you can pack it with ice! i ordered the one that is designed for the previous gen mustangs because it is a little shorter than the direct replacement one for the cobra...
i will let you know once i get it installed and working...and yes i will make sure i take some pics with this so that you can duplicate it.
i am also considering putting together a complete bolt-on kit that you could order directly from me with pictured instructions along with the heat exchanger, reservoir, hoses, fittings, clamps, etc...
cool. thanks for taking the initiative. i'd be interested in something like this. keep us updated on your progress.
Old Oct 4, 2006 | 06:17 PM
  #53
Eurocharged Rick's Avatar
SPONSOR
will do!
Old Oct 4, 2006 | 06:36 PM
  #54
Bif powell's Avatar
2002 c32
I love you and I want to have your children.
Old Oct 4, 2006 | 07:18 PM
  #55
SPONSOR
i already have kids, but thanks for the offer...
Old Oct 11, 2006 | 12:08 AM
  #56
smgC32's Avatar
The Evosport mod accomplishes the goal of seperating the systems. I am working on a larger unit to hold more fluid, around 4 gallons. If you are worried about having a seperate windshield fluid resevoir, install a small pint or quart holding tank for this fluid that will fit with the bumper cavity. Not a problem to do and one I will do when my car is finally complete. Preliminary numbers are around 3,500 to 4,000 for a larger heat exchanger, newly designed aftercooler, plumbing and a new fluid resevoir. This has taken much longer than anticipated. I currently have two people interested. Please indicate how many of you are interested within this thread so I can determine if more than just one unit should be made. Currently the car does not exceed 135 degree F in AIT in 95+ ambient temps at 30 minute intervals.
Old Oct 11, 2006 | 12:12 AM
  #57
jgsx's Avatar
04 C32
Great product, but 3500 is too expensive. The 4 gallon resevoir alone will be a huge upgrade over the stock system, and I'd pick one of those up
Old Oct 11, 2006 | 12:14 AM
  #58
SPONSOR
the price point is what is steering me in the other direction...i am going to see what i can accomplish with these units that i picked up, i will keep you posted...
by the way guys, they just arrived today...i will take some pics and let you know when the install date will be...
Old Oct 12, 2006 | 10:22 PM
  #59
m444's Avatar
Audi C7.5 S6
Wow, 4 gallons, where are you putting it? In the trunk? I think the stock intercooler system is the weakest part of the car. I may be interested, if it does hack up the car too much, but a 4gal tank is huge.
Old Oct 13, 2006 | 11:37 AM
  #60
Zeppelin's Avatar
C32
So has anyone done any testing to prove that all this work is going to produce any more horsepower. Has anyone dyno'd the car with stock intercooler and then say run the pump suction line into a bucket of ice water on the dyno to see if it makes any horsepower. Seems like an easy test to at least determine whether all this work and dollars are going to pay off.
Old Oct 13, 2006 | 11:56 AM
  #61
m444's Avatar
Audi C7.5 S6
I can tell you my C32 definately gets heat soaked. The power is way up on cooler days. The retard for the ignition timming is controlled by the knock sensors and the air intake temp. When the air intake gets too warm, timming is pulled. When there is detonation, timming is pulled.
I suppose, if one had 100 octane fuel, all the time, less timming would be pulled.
The timming is pulled quickly, but advanced much more slowly, so once timming is pulled, it takes a while to back to normal.
Adding a pulley kit just makes the situation worse.
Old Oct 13, 2006 | 12:16 PM
  #62
SPONSOR
the reservoir that i purchased is made to be packed with ice...trust me, i will be using the ice for some testing and at the track...i am also going to purchase a scan tool so that i can reaad the actual IAT and timing numbers
Old Oct 13, 2006 | 03:22 PM
  #63
Zeppelin's Avatar
C32
What I am saying is the intercooler radiator and pump may not be the problem with heat soak. It is opossible that the intercooler core(underneath the supercharger) is the problem. You can put all the ice water you want through the system but it may make zero difference.
Old Oct 13, 2006 | 04:29 PM
  #64
jgsx's Avatar
04 C32
The mod won't give you more power on the dyno. I have 0 interest in a resevoir packed with ice. The larger resevoir will just prevent the car from losing power after multiple runs in a row.
Old Oct 13, 2006 | 08:12 PM
  #65
Zeppelin's Avatar
C32
I have never had a problem with the car losing power after back to back runs. I ran the car at a dragstrip here in SoCal on a 95 degree day with no more than 5 minutes between runs. Car ran near identical times at 13.2@111 all 8 times in a row. I have also had the car at Willow Springs road course on 110 degree days and it will not lose power during the 25 minute sessions.
Granted the car makes more power on a cold morning versus a hot day, but I am not sure a larger reservior will solve this. Maybe it will.
IK-22 plugs have really cured most of my heatsoak issues. Car runs like it is running on race gas with 91 octane.
Old Oct 13, 2006 | 10:41 PM
  #66
m444's Avatar
Audi C7.5 S6
The IK22 (colder) plugs may help on hot days, when the knock sensors cause it to pull timming (which is also dependant on IAT).
The whole IC system needs rework, both heat exchangers, under the blower and in front of the radiator, the reservoir and the coolant pump.
Old Oct 13, 2006 | 10:55 PM
  #67
SPONSOR
i will bet money that this statement is wrong...
if the car pulls timing because the IAT is too high and/or there is any detonation present, then you make less power...the cooler the IAT, the more timing the car will allow, up to the max it is programmed for...
i live in houston=lots of heat and humidity, the two together are a bad mix for performance, especially forced induction...
Old Oct 13, 2006 | 11:08 PM
  #68
m444's Avatar
Audi C7.5 S6
go to this webpage, for a one year $24.95 subscription, for one car:
http://www.alldatadiy.com/index.html
For C32, look under "Powertrain Management" >> "knock sensor" >> "Description and Operation" >>" Anti-Knock Control Function"
Lots of interesting info.
Old Oct 14, 2006 | 12:44 AM
  #69
jgsx's Avatar
04 C32
Right, so on the dyno, your first pull is with cool coolant. Having a larger resevoir won't show up on the first pull. After making a few pulls, the larger resevoir comes into play and the power level is more consistent. With the stock resevoir you're going to heat up, increase IAT, increase chances of detonation, increase chance of ignition retard which all translate into losing power.
I didn't mean that adding ice won't give you more power on the dyno. I think that you would gain. I meant that I don't care about ice because I'm not going to ever put ice in my resevoir.
Old Oct 14, 2006 | 12:46 AM
  #70
jgsx's Avatar
04 C32
The car pulls harder during cooler weather for several reasons, and cooler coolant is only one. I'm not saying that a larger/cooler resevoir is the cure all for everything, but it is one variable that you have control over.
Old Oct 16, 2006 | 07:43 PM
  #71
SPONSOR
just wanted to update this...
i am waiting on a battery relocation kit to come in, the battery is going to have to go in the trunk in order to make room for the intercooler reservoir under the hood...going to buy an optima battery as well while i am doing the relocation.
i will keep you posted on when i am going to have a chance to do the install...
Old Oct 16, 2006 | 08:02 PM
  #72
430's Avatar
430
SLK32
How about some pictures
Old Oct 16, 2006 | 11:02 PM
  #73
SPONSOR
i will post some pics of everything once i get the battery relocation kit in...
Old Oct 17, 2006 | 12:15 AM
  #74
smgC32's Avatar
The intercooler/aftercooler under the supercharger is part of the problem. That is why I have reworked the flow on mine and having a custom one being built which increases the volume that flows through it. The entire cooling system needs to work together. The point of this exercise is not to make more power, but how not to loose power under heat soak.
Old Oct 17, 2006 | 12:20 AM
  #75
SPONSOR
how exactly are you reworking the intercooler?
i would still love to see some pics of the intercooler...
i agree with you on not loosing the power that is there, heat soak sucks...
