BMW 335i sedan: 0-60 in 4.8 sec
http://www.leftlanenews.com/2006/09/...in-48-seconds/
BMW 335i sedan: 0-60 in 4.8 seconds
BMW's 328i and 335i sedans had perhaps one of the most quiet rollouts of any automobile in recent memory. The German automaker never issued a press release, nor did it make any effort to overtly advertise the demise of the 325i or 330i in favor the new, more powerful models. This might lead one to believe the upgrades are minor, but nothing could be farther from the truth. In a newly-published road test, Car and Driver magazine reports achieving a zero to 60 mph time of just 4.8 seconds. That puts the five-seater sedan on par with the current-generation M3 coupe. Reaching 100 mph takes just 11.8 seconds. The 3616-pound four-door achieves these impressive numbers thanks to a twin-turbo inline-six with a claimed output of 300 horsepower. Of course, there is a great deal of speculation that the engine is actually more powerful that BMW says. Recent dynamometer tests of the 335i coupe tend to confirm this theory.
Link to the video:
http://videos.streetfire.net/recentv...44013bcc63.htm
Not bad for 300hp. How do you think it will compare to C55's?
Its making 280+ to the wheels, with as much torque...
thats 340hp+ and 340+ torque..
some Dyno runs it has hit 290's+
just a chip and downpipe.. and it will be close to 400hp
for those of you with a C32.. pulley and chip (NOW!)
Given that the 335i will have 1 extra gear, better weight distribution, from a roll or stop.. I take the 335i stock vs the C32.
(if I do keep the C32, I need the ECU for sure!)
I'm sorry but I just don't believe it . A buddy of mine just told me a friend of his got one, so I'm going to see if I can set up a race with him. On another note there I believe might be one to drive at the BMW Performance Drive in Fontana on the 16th, so I'll see how this thing really performs. I don't think it could pull on a stock C55 or C32 for that matter.
http://www.dynocomp.com/bmw.php?view=bmw
http://www.automobilemag.com/featur...i_dyno_revised/
Dynoed a different 335 again.
few weeks ago, we got a surprise visit from the new BMW 335i coupe, one of the hottest cars of the year. We’d been quivering in anticipation for the 335i not because it’s a 3-series--although that pedigree doesn’t hurt--but because the mind-meltingly fast two-door offers BMW’s first turbocharged gasoline engine ever to be sold in the States.
With this in mind, we just had to take the new coupe to the dyno and see exactly how much power its twin-turbo powerplant puts to the ground. The results? 275 hp and 300 lb-ft of torque at the rear wheels--more than we expected. Rated by the Bimmer boys at 300 hp and 300 lb-ft of torque, it was pretty clear to us that the Bavarian masterpiece was a little underrated from the factory.
In the weeks since we first published the results of that test, we’ve heard some criticism of our conclusion that the 335i makes "closer to 350 hp" than the reported 300. We arrived at that verdict after some quick calculations, but since a chassis dyno only reports how many horses make it to the wheels, it’s admittedly a hard number to verify. We did four runs with that particular car, and the actual peaks were 276, 280, 280, and 283 horsepower. We published the lowest number to be sure there was no claim that we were exaggerating the engine’s output.
But what if this was a one-time fluke? What if that first 335i was a particularly strong example? Or--gasp--a ringer! The answer to that question appeared in the form of another 335i (this time painted space gray metallic) that BMW dropped off last week. Again, without hesitation, we grabbed the keys and headed for the dyno shop.
2007 BMW 335i Coupe Rear Corner
On the way, we were pleased to find intact the awesome midrange torque and incredible straight-six soundtrack. Reacquainting ourselves with the gauges, we noticed that, as with the original tester, the oil temperature stabilized at 240 degrees Fahrenheit while cruising in sixth gear at 80 mph. Lesser engines would melt at those temperatures!
Temperature? Wait! A quick look at the outside temperature display showed that it was only 78 degrees Fahrenheit outside. The last time we put a 335i on the rollers, it was 92. Everybody knows that engines make more power when they get cooler air--and that turbocharged engines are particularly susceptible to heat soak. We stopped worrying and started getting excited. This one might do even better.
We strapped the 335i down, started it up, and did three runs back to back to back. The results were very consistent, showing peaks of 285 hp, then 282 hp, and, finally, 287 hp. This 335i was even stronger at the top end than the last one, but not as strong in the midrange. Peak torque was stable through all three runs at about 285 lb-ft.
After the final run, we decided to grab audio of the 335i running from first gear through fourth. We expected to have the hairs on the back of our neck stand up at the sound of the 3.0-liter engine at full throat, but what we didn’t expect, of course, was a peak hp number nudging the 300-hp mark. That’s right--shortly after the shift into fourth, this second 335i peaked briefly at 299.93 hp.
Looking closely at the chart, there’s a likely explanation for that outrageous number. No, it wasn’t additional torque from a rough shift--the peak occurred too long after the gear change. Like most turbocharged cars, the computer allows a momentary spike of boost before stabilizing it at a prescribed level. We lucked out, as that spike happened right at the engine’s inherent power peak, so we got a little nudge in the final number. Whether the dyno numbers ultimately translate into 300 hp, 350 hp, or 327.543-to-the-fifth-power-hp, the results speak for themselves: this is one very powerful engine.
Laptime Nordschleife 8.26 min (4 seconds slower than M3)
Laptime Hockenheim 1.17,8 min (0,8 seconds faster than C55 and 1.5 seconds slower than M3)
0-100km/h 5.6 sec
0-200km/h 20,7 sec
36m slalom: 130km/h (M3 123km/h, C55 122km/h)
110m change lane: 136km/h (M6 137km/h, M3 136km/h, C55 134km/h)
Wet track: 1.36,8 min (M5 E60 1.36, 7min)
G-powers: 1.15g (C55, 1,10g and M3 1.10g)
Overall score: 45 points (1 point better than M3)
BMW, are they cheating? it is called the 335i even though it comes with a 3.0-litres bi-turbo engine. But the two 39mm turbo chargers give it the advantage same as 0.5 litres more displacement.
The powerful engine has no problem with the weight of the car, always offers enough power and makes it a pretty good performer even though it has no "M" in its name.
The engine and 6-spped manual transmisison are a pefect peering, only there is no mechanical limited slip differential but an ESP which always interferes with throttle and gas, lacks a bit of traction. But the power of the engine always preserves the enthusiam of driving one.
You have to get used to the new active steering whoch gives a preview on the future things to come from BMW.
The 335i is a true dream car, nothing else, the quickest coupe without the "M" in its name.
Acceleration 335i:
80-120km/h 4/5/6 gear: 5.5 s /6.5s / 7.9s
80-160km/h 4/5/6 gear: 11.4s/13,7s/16.7s
80-180km/h 4/5/6 gear: 14,8s/17,8S/ ---
M3
80-120km/h 4/5/6 gear: 5,2 s / 6,6 s / 9,5 s
80-160km/h 4/5/6 gear: 10,9 s / 13,9 s / 18,9 s
80-180km/h 4/5/6 gear: 14,1 s / 17,4 s / 25 s
C55
80-120km/h 4/5/6 gear: 6,3 s / 7,9 s / --- s
80-160km/h 4/5/6 gear: 12,8 s / 15,9 s / --- s
80-180km/h 4/5/6 gear: 16,3 s / 20,2 s / - s
Quoted from another fourm:
"Well, to bring this thread back on topic, here are some more detailed numbers from the Sport Auto test of the 335i. In their article, they listed the numbers from the E46 M3, W203 C55, and B6 S4 Avant which were tested previously. Here are the major categories of their test.
Nuburgring laptime:
1) M3: 8.22minutes
2) C55: 8:22 minutes
3) 335i: 8:26 minutes
4) S4 Avant: 8:29 minutes
Hockenheim laptime:
1) M3: 1.17,6 minutes
2) 335i: 1.17.8 minutes
3) C55: 1.18,6 minutes
4) S4 Avant: 1.19,1 minutes
0-200-0 km/h
1) M3: 23.2 seconds
2) C55: 23.7 seconds
3) 335i: 26.3 seconds
4) S4 Avant: 26.4 seconds
Transverse acceleration:
1) 335i: 1.15 g
2) M3: 1.10 g
3) C55: 1.10 g
4) S4 Avant: 1.05 g
Slalom course (36m)
1) 335i: 136 km/h
2) M3: 123 km/h
3) C55: 122 km/h
4) S4 Avant: 121 km/h
Evasive course (110m)
1) 335i: 136 km/h
2) M3: 136 km/h
3) C55: 134 km/h
4) S4 Avant: 130 km/h
Total points indicative of the "overall assessment"
1) 335i: 45
2) M3: 44
3) C55: 42
4) S4 Avant: 37
In other words, Sport Auto, which places an emphasis on handling rather than straight line speed, ranks the new 335i above the E46 M3. Quite an achievement for a non-M car with stock 17" rims"
It seems that the 335i is a better choice than the E46 M3
http://www.dragtimes.com/BMW-335i-Timeslip-9827.html
http://www.dragtimes.com/BMW-335i-Timeslip-9852.html
