slight plastic burning smell from engine
Old Oct 22, 2006 | 02:14 AM
14cue's Avatar
05 C55
Question slight plastic burning smell from engine
i STFF and couldnt find an answer to my question...
i have an 05 c55 with 26k km on it. i have noticed that there is a slight burning scent coming from the engine which comes in through the vents. it's a subtle rubber or plastic smell. even if i was to take the car for a spin just around the block i would smell it. its stronger in the car than when i step out and pop the hood to take a sniff.
does anyone have this issue or have any insight? i will be bringing it in for a service check next week.
thanks in advance.
Old Oct 22, 2006 | 03:40 PM
alterego's Avatar
Black 2002 C32 AMG
Take your plastic motor cover off and take a close look at your belts or plastic cover. I had that smell on my c32 one time but shortly after a tensioner broke then belt got locked up and total shut down.
Old Oct 22, 2006 | 04:09 PM
14cue's Avatar
05 C55
@alterego, thanks!
is it fairly easy to take the cover off?
Old Oct 22, 2006 | 04:49 PM
sdsilverm3's Avatar
Terrence,
Here are some instructions off of Neal's site:
Engine Cover Removal
Old Oct 22, 2006 | 08:29 PM
14cue's Avatar
05 C55
thanks Ling.
i realized Euroteck had instruction on removing the cover right after i posted (doh).
i did take it off, everything appears to be in good order.
Old Oct 24, 2006 | 02:46 AM
power-fade's Avatar
"One Man. One Engine."
Originally Posted by 14cue
thanks Ling.
How long did it take you to take it off?
Old Oct 24, 2006 | 04:11 AM
sdsilverm3's Avatar
Did you ever figure out where the smell was coming from?
Old Oct 24, 2006 | 12:12 PM
14cue's Avatar
05 C55
richard,
it took less than a few mins. simply pull it off.
Ling,
not yet, im goingt o leave it to the dealer. im just waiting for a call back then i will bring the car in.
