do i need to replace the sensor if i'm replacing brake pads??
If you are like me, you'll replace your brake pads long before you trip the sensor; and you check pad wear frequently. I disabled the sensors in the front of my car because I didn't have OEM sensors (cheap+lazy). To do so, you need to close the circuit to make the car think that the sensor has not been tripped. You do that by stripping and twisting the wires from the sensor leads.
C32 AMG
Forgive my ignorance, but what is this sensor? Just something that is supposed to tell you when to replace your pads? Does it just show up as a malfunction on the display when it's tripped? I have yet to replace my pads....
How many miles are you guys getting on a set of OEM pads?
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
i switch between race and stret pads very often i don't even insert the sensor just leave it wire tied to the side. i re insert it after i'm done tracking the car for season (nov).
i really don't need the sensor as i know how much pad i have left at any given point.
