SPONSOR
it is good to know that they are willing to stand behind their product though...at least it looks positive!
Quote:
Actually, I've always thought the same thing until last year when a member on this board who had Kleemann cams installed in his C32 confirm that they are not. He told me that he asked Kleemann if Schrick makes their cams, and they said no.Originally Posted by jgsx
Rumor is that Kleeman cams == Schrick cams
Quote:
+1... I would take pictures, measurements, videos, and everything else you can think of just in case any issues arise later.Originally Posted by 1FASTC32
get the cams measured before you send them back...this way you have some evidence in case they try to blame something else...
In the mean time, have fun with the car....
After all this, you definately deserve it....
Just a question there: high lift camshaft wouldn't hurt the mid range torque?
Cheers.
Cheers.
Ok. I wasn't sure if they were the same. I had heard from a few auto soruces that they were likely the identical product.Originally Posted by MB_Forever
Actually, I've always thought the same thing until last year when a member on this board who had Kleemann cams installed in his C32 confirm that they are not. He told me that he asked Kleemann if Schrick makes their cams, and they said no.+1... I would take pictures, measurements, videos, and everything else you can think of just in case any issues arise later.
sales@eurocharged.com
SPONSOR
close
- Join DateAug 2006
- LocationHouston
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveC63S
Liked:130 Times in 93 Posts
MB did the compression test and the left side has 150 PSI across the board. The right side starts out at 150 PSI, then 120 PSI, then 60 PSI.
I have taken the adivce of John and Vadim and MB is going to measure the right side lobes and see if there is a difference. If they are different, then they are going to remove them and install the AMG cams. If they are the same, then I will have to come up with a plan B.
Vadim - Sound right? What should we do if the cams measure the same?
They are also going to let me take pictures of the measurements if they are off.
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Quote:
They are the same....Kleeman wouldn't advertise this fact.Originally Posted by jgsx
I have had two people from Schrick mention that they have agreements with these tuners and sell them an exclusive cam.
It could all be hot air.....but you never know.
Even though they may make the cams for other tuners does not mean that they are the same exact profiles. They usually grind them to each tuner's specs. It would be interesting to measure both sets to see the differences, just as it would be to test the PSS-9's and Carlsson RS's for shock valving specs. Very hard to find two owners with these mods to take them off the car and do testing. Keep up the hard work!
Hi Folks: My Main PC took a hi from lighting
. So I'm limited to posting Pictures. As engineering Buddys, we like to post true numbers , on any changes we have made,
We may not know when to come in out of the rain, It is our focus & dedication to record true facts at the best of our capibility. So we may have some repetibility on Our Mods. Although I did not go as full out as others on the porting. I did post some flow bench Numbers. We also used a (J)tip on the end of the probe, As recommended By Jim McFarland & Smokey Yunick. Well Todays post is the Valve spring height assy & pressures . Happy Motoring from the SCHOOL OF HARD KNOCKS ___PTE___
You May want to Visit the W-211 threads & Type in { Project___PTE___ } or W-209 clk 5.5 amg { ___PTE___ project } I've got some good Flow bench Pictures there
We may not know when to come in out of the rain, It is our focus & dedication to record true facts at the best of our capibility. So we may have some repetibility on Our Mods. Although I did not go as full out as others on the porting. I did post some flow bench Numbers. We also used a (J)tip on the end of the probe, As recommended By Jim McFarland & Smokey Yunick. Well Todays post is the Valve spring height assy & pressures . Happy Motoring from the SCHOOL OF HARD KNOCKS ___PTE___You May want to Visit the W-211 threads & Type in { Project___PTE___ } or W-209 clk 5.5 amg { ___PTE___ project } I've got some good Flow bench Pictures there
Exploresales@eurocharged.com
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Well, I got my car back today with the AMG cams installed and it runs fine.
MB did measure the lobes on the cams and did notice a difference from one lobe to the other. They also did a compression check and Cyl 1 is back up to 150 PSI.
I have to go back tomorrow because my check engine light is on due to an O2 sensor and they didn't have it in stock.
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Well, I have had the car a few days now and have managed to put 200 miles on it. It is running very rich, and this is something I thought my car would never do, considering all of the previous vacuum leak issues, etc.
I have a front O2 sensor that is out and I'm waiting on the part to arrive at MB so I can go have it installed.
There is a small amount of black smoke that is coming from the exhaust when the car is at idle. The rough idle has also returned, and the car shakes like a hungry old 5.0 Mustang.
I'm not going to post my thoughts on the new power... I have had the C280 so long that I don't remember how it use to feel. I do know that the throttle in more sensitive and it does seem to have more of a "peppy" feel to it.
I will try and get a Dyno done before the end of the week.
The Schrick cams will be going back tomorrow if I can't find a local company to measure them for me. I want to be certain they are the issue before I send them off.
I'm now debating on sending the ECU back to Renntech to have it flashed back to the old map. I'm sure the new map and added fuel can't be good considering I don't have the cams installed.
Wish me luck at the Dyno...
If you are having O2 sensor problems you should get that resolved before having the ECU re-flashed and dyno's done. MB does not have an O2 sensor in stock?
Lets hope the O2 is causing all the rough idle problems.
hang in there Jerry.
the rough idle and "black smoke" makes me think you have a misfire. the black smoke may be unburnt fuel.
i agree with zep. get the o2 sorted out 1st before dynoing.
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Yup...I tried to get it installed Saturday, but the part didn't arrive. I was told it should arrive this afternoon, but I won't be able to make it until tomorrow. The Dyno Appt should be around Friday.
I'm driving the car like a grandma now.....I wouldn't dream of putting her on the dyno like this.
Good luck Jerry. I'm still waiting on new headers before I can start the car.Originally Posted by AMG-Jerry
Yup...I tried to get it installed Saturday, but the part didn't arrive. I was told it should arrive this afternoon, but I won't be able to make it until tomorrow. The Dyno Appt should be around Friday.I'm driving the car like a grandma now.....I wouldn't dream of putting her on the dyno like this.
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Quote:
MB ordered by the wrong O2 sensor, so I said $%$% them and drove to another MB dealership and picked up the 02 sensor I needed. I had a friend who owns a repair shop put it in for me. I then went next door and had a guy with a StarDAS clear the adaptations / error codes.Originally Posted by 430
Any Updates?!?!
The car runs like a monster now. No rough idling or hesitation. I got 17 Mpg to the gallon on the way home.....which is much better than the 10 I was getting earlier this morning.
I'll hit the Dyno ASAP and let you know the results.
Anyone care to guess what my gains will be...if any?
The person who gets closest without going over will win a nice Mercedes flashlight, pen, and tire pressure gauge combo set (see pic).
Jerry i say 10 hp from midband up to 15 hp peak. dynos are not consistent tho.....your 1/4 miles times may be more indicative of the added power.Originally Posted by AMG-Jerry
The car runs like a monster now. No rough idling or hesitation. I got 17 Mpg to the gallon on the way home.....which is much better than the 10 I was getting earlier this morning.I'll hit the Dyno ASAP and let you know the results.
i am relieved for you....almost like it was my own car.
thanks for taking this on. you have big *****.
I don’t think O2 sensors have any effect on a dyno run. O2 sensors are only used when the engine is in closed loop mode. They go into closed loop at idle and at cruise. On a regular dyno pull, the engine is at wide open throttle (WOT). Bosch fuel injection systems use maps to regulate fuel at WOT. I’ve removed the factory O2 sensor and plugged in a wideband for dyno runs – leaving the OEM cable unplugged. The light comes on, but it has no effect on the run.
I think you’re making the right decision in doing the dyno run with the existing ECU code. If the AF ratios are good, you’re probably OK. I’d have reservations about undoing the flash because the timing was probably changed when the ECU was remapped and you may not wish to loose that. As for the reflash causing it to run rich while in closed loop mode (with working O2 sensors), that usually isn’t the case. You may wish to call Renntech and confirm that the car is capable of running normally (lean) while in closed loop mode. If it can’t, then I have no idea how anyone in California passes smog with an ECU that Renntech has reflashed. Our smog tests are designed around the car being in closed loop mode.
I also think you did the right thing in getting the O2 sensor as soon as possible. With a dead O2 sensor, the ECU will use maps for idle and cruise. The default maps are quite a bit richer than being in closed loop, and running rich for prolonged periods at idle and cruise will overheat (and kill) the cats.
I'm guessing a 27 HP peak increase on the dyno
Quote:
I'll say 28 HP (the ol' +1 technique on the price is right FTW!!!!).Originally Posted by MarcusF
I'm guessing a 27 HP peak increase on the dyno[/FONT]
Quote:
Nah, I say he gains 31 rwhp. Originally Posted by TJ_Andrews
(he's happy, it passes the butt dyno, and he's giving out prizes!)
If he gains anywhere near those numbers at the wheel, I'm sure he'd be happy, cause that's impressive.Originally Posted by boohooramblers
Jerry, I call 30 wheel horsepower increase over last dyno...Originally Posted by AMG-Jerry
I'll hit the Dyno ASAP and let you know the results.Anyone care to guess what my gains will be...if any?
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Wow, you guys are optimistic!
I do have to admit that the numbers will be a little off. If you remember my last dyno, I was struggling with the car running a little lean. There was a slight knock at the top end that was annoying and I never thought it would be fixed. Well, even though I don’t have the cams installed, I’m happier that the car now runs correctly and hopefully the A/F Ratios will be right on target. It sucks that this couldn’t have gotten fixed sooner, because we will only have an estimate of what the porting / valve job will give us in the power department.
I’m going the refrain from posting my thoughts on the power because I have never been a good street tuner. In fact, I thought the car was making more power when it actually was making -20Whp!
There are a few spots by my house where I have done some runs over the past year and I have managed to keep a log of those times / speeds. I have an idea, I just don't want to throw your guesses off.
On a side note, I was heading to the office this morning when a sexy new Porsche turbo pulled up beside me, waited a second, then he nailed it. You know me… I had to follow close behind him. At the next light, he was first and I was second, and there was about 1 mile of open road in front of us. I could see him looking back at me in the mirror while he was rocking his car forward. I knew I was going to lose the race, but I wanted to see what his car would do and how brave he was on a 40mph street. Well, the light turned green and of course he nailed it. Being the sucker that I am for fast cars, I did the same. He was about 3 car lengths ahead when we hit 80, then he let off. If I was driving that car, I would have beaten me in to the ground. At the next light I pulled up beside him and I looked over to see a thumbs up coming from him. I returned the gesture and when the light turned green, I slowly drove off. It’s nice to find a guy that likes to play and appreciates fast cars. It was cool to see him shift too. When he would change gears I would gain fast, then he would pull again. I love the consistent power of our car….if he would have missed a shift, I would have hit his bumper for sure.
Here a couple of low res camera phone pics that I snapped.
Without the cams, I am guessing a total of 353rwhp. I picked up 32 rwhp from stage 2 heads on my vette without milling them.
SPONSOR
close
- Join DateAug 2006
- LocationHouston
Quote:
LOL...The last dyno run was over 360Whp.
The graphs that are on here are old.-7 here we come!
