Coilover install
Old May 3, 2007 | 09:37 AM
overboosted's Avatar
2012 E63, 2016 1299
Coilover install
Any FAQs done for a coilover install on C32?
I have done springs and shocks on VWs, Hondas, DSMs, and a Supra before. It seems most people here take their cars to somebody to get stuff done.
Are any special tools needed? Any online guides?
Thanks!
Old May 3, 2007 | 01:27 PM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
If you have done standard suspension installs on those other vehicles, then there really wont be much of a difference. I installed my coilovers last month, and it was as straightforward as any other car. They went on without a hitch. I used my alldatadiy.com subscription for any information I needed (great value @ $14 for a year). Pm me if you have any specific questions. Good luck.
Old May 3, 2007 | 01:33 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yeah, if u have DIY experience with suspension, i wouldn't worry about it...
Old May 3, 2007 | 01:47 PM
360_iti's Avatar
W203, W211, W219, W212
The rears are easy.. I could do it with one hand. The front is a little bit tricky IF you plan to take it back to stock someday. If that's the case, then you would want to get an extra set of spring hats for your new kit.
This is why.. in order to install the new kit, you need to use the stock spring hat from the stock struts. Undoing the stock spring hat is easy. To install it back on the stock struts (again if you plan to take it to stock) is a major PITA. That's why you'd want to leave the original spring hat intact.
Old May 3, 2007 | 02:13 PM
2012 E63, 2016 1299
Any special tools required? I know for my VW GTI I needed to rig up a special tool (gring a socket) to get the struts apart.
Old May 3, 2007 | 06:12 PM
ultraman206's Avatar
M5
Thanks for the heads up. I am about to install some CO myself... sheit I thought I was in the clear buying coilovers with just straight swap installation; didn't know I still have to disassemble the OEM unit.
How much are these spring hats? Does anyone have the part # handy?
Old May 6, 2007 | 09:41 AM
sdsilverm3's Avatar
It's only a major PITA to reinstall the stock spring hats onto the OEM shocks if you don't have a spring compressor. We did the front coilovers on my car to check for clearance and then went back to stock on the same day with no issues. It should be pretty straight forward.
You might need this though. Not required but sure would make your life easier.
Old May 7, 2007 | 12:40 AM
360_iti's Avatar
There you go. I'd say that particular tool would make your life a lot easier.
Old May 16, 2007 | 03:06 AM
1via's Avatar
1996 Volvo 850 Turbo Wagon, 1991 Nissan 240sx track car
This socket is for what? The front tophat nut?
