PTT voice lever? where to get it?
Old Jul 9, 2007 | 11:38 AM
davidbho's Avatar
X166, 997
Anyone, help! I need this part: Q6820551. It is a PTT lever for a 2002 C32. I think it works on all 2002 C class.
Discontinued at MB, anyone? any ideas?
Thanks!
Old Jul 9, 2007 | 02:00 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Thanks!
The lever in my 02 C32 looks just the same as the lever in the 07 C280 I drove for a month. Maybe you could use one from that model...
Old Jul 9, 2007 | 03:24 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I just recently purchased one for my C55 - the part was current and available at the dealer. I paid <$15. The lever should be the same for all W203s.
I believe that I purchased part number Q 682 08 37. The part number you note is listed by MB as for an SLK.
Old Jul 9, 2007 | 03:42 PM
WaveyKat's Avatar
Something Slow
oem parts direct has that Q 682 08 37 lever for $13.94 and Q6820551 for $11.48 good luck finding the right one!
Old Jul 9, 2007 | 05:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Q682 06 51 is the part # i found...
Old Jul 9, 2007 | 05:53 PM
WaveyKat's Avatar
Something Slow
MJ do you have this feature in your car?
Old Jul 9, 2007 | 05:56 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i doubt it...
but i still want to have a lever...
Old Jul 13, 2007 | 06:04 PM
davidbho's Avatar
X166, 997
Thanks guys!
Thanks guys, ordered both, one of them should be right...the one I have now is a little messed up, it comes loose, i think it's the e-class one...whatever, should have it in a few days.
Old Jul 13, 2007 | 06:06 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
pls post both pics and let us know which one worked (if not both)...
Old Jul 16, 2007 | 01:32 PM
davidbho's Avatar
X166, 997
Will do...
should be sometime this week, hopefully.
Old Jul 17, 2007 | 01:37 PM
WaveyKat's Avatar
Something Slow
ok QUESTION if i was to buy one of these lever and install it should i have voice comand working or do i need to install another part? i have a 2001 c320
Old Jul 17, 2007 | 02:41 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i think u need some module...
no idea how to find out if equipped with one or not...
Old Jul 18, 2007 | 01:58 AM
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
sorry for a stupid question?
what does this doo??
Old Jul 18, 2007 | 03:03 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
it allows u to use voice commands to use functions of COMAND...
kinda common on japanese cars...
Old Jul 18, 2007 | 03:29 PM
davidbho's Avatar
X166, 997
Exclamation No luck ordering
OK guys, just checked OEM parts direct, and they cancelled my order, with "part unavailable". Any other ideas???
To the other dude, asking about VCS. It's Voice Control System and it is awesome. I have it in my car, and I pull the stick, and say "dial name", car says "name please", I say "whatever name", and it dials it. I can also say "CD 2, track 5" and it goes to it...bla bla bla, it's awesome. I also have the blue tooth puck installed into the phone cradle, and love that.
Old Jul 18, 2007 | 03:42 PM
dkflipse's Avatar
C32 AMG
Sounds cool. Please keep us updated on what solution you come up with.
Old Jul 18, 2007 | 03:52 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
which part # did u use???
Old Jul 19, 2007 | 12:56 AM
aww isee
how well does it work and what does it control. is it anything like the acura system?
Old Jul 19, 2007 | 10:49 AM
slowrey's Avatar
2006 Mercedes C55 AMG
What I hear is that it will cost about 600 bucks for parts.
Old Jul 19, 2007 | 06:52 PM
davidbho's Avatar
X166, 997
I got all the voice related stuff for like $150 on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...m=300071759158
those are all the parts I used...already had the phone related stuff, added that and blue tooth puck for about $300, and I was golden...now I just have this issue of a loose PTT lever that comes off when I push it up.
go here for all the things you need to know about installing it...
http://home.earthlink.net/~phdwebsit..._bulletins.htm
it actually has the installation guide that includes the voice stuff...
SO NO ONE HAS ANY IDEAS TO GETTING THE RIGHT PART??
Old Jul 19, 2007 | 07:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
wonder if VCM module will work without phone kit... i'd assume it should...
Old Jul 19, 2007 | 07:46 PM
slowrey's Avatar
Do we know if this will fit a W203 2006?
Old Jul 20, 2007 | 10:05 AM
kjb55's Avatar
It won't work in the 2005-2007 cars. These are MOST ring, the 2004 and below cars are D2B.
I did the install on my 2005, and the parts are different, except for the PTT lever - that looks identical to the one I used.
It's mentioned above that it (PTT lever) comes loose - if you can easily pull it out, then it's not installed correctly, and that's why it's loose.
Old Jul 20, 2007 | 11:47 AM
slowrey's Avatar
Do you have part numbers from you 2005?
Old Jul 20, 2007 | 12:21 PM
davidbho's Avatar
X166, 997
Unhappy Pretty Positive I have the wrong lever
if you go to the link i posted on how to do it for a 2002 C32, page 4, figure 5, that's the lever that matches the other levers (cruise and signal indicator). The one I have on there, matches the 2003 and above ones. And it's shorter then the one I have on there now.
And it doesn't really come off that easy, thing is, when you turn it down and in, it stays, but every time i pull the key in and out, it moves up..and if i let it move up all the way, after hitting it a few times, it pops out.
I tried everything, even calling other dealers, no dice...part is gone, and I'm SOL.
