Hidden A/C Menu
Press and hold the A/C Off / EC Rest button on your C32 until a different display comes up. You'll notice that there are two digits that flash on each side of the A/C screen. If you press the Auto button on the drivers side, the numbers will increment from 00-99. I have been using the 06 code and the 01 code.
01 In-car temperature sensor.
02 Outside temperature sensor.
03 Heater core temp, left.
04 Heater core temp, right.
05 Evaporator temperature sensor.
06 Engine coolant temperature.
07 Regrigerant pressure in bar (e.g. '4' is 4 bar).
08 Refrigerant temperature.
09 Not used.
10 Heater blower control voltage (normal 08-6.0, meaning .8 to 6 volts).
11 Emissions sensor voltage (to detect atmospheric gases and recirculate interior air).
12 Sun sensor voltage (to shift airflow in car).
20 Control current for auxilliary fan (electric fan on radiator, given in milliamps or mA).
21 Engine speed (x100).
22 Road speed (km/h or mph depending on installation).
23 Battery voltage at terminal 58d (as a percentage of total voltage, e.g. 99.0 = 99%).
24 Battery voltage (e.g. 12.8 = 12.8V).
40 Climate control software version.
41 Climate control hardware version.
To exit, press the A/C Off / EC Rest button again.
I'm sure there are other cool functions that we don't know about.
Dumb question but what are you guys getting for the battery voltage?? My display flashes 06, then 1 36??
I take it 13.6 volts?????????
suspected cause...burnt out license plate bulb caused an open loop and drain the battery...
http://www.eclassbenz.com/node/27
ohlord
"GOT CODES?"
you only need to read values 1-8 and then do the error mode test and record those numbers.........
