driver's side seat heater replaced again
Anyone know the trick to making them last longer? I'm only 180 lbs. OK maybe 185. And I'm very careful about not putting alot of pressure on one spot. i.e. knee on seat to reach across to passenger side.
mine went the 2nd time and never bothered to fix. in the the grand scheme of things it's no biggie.
Mine went out at 14,000 miles, can you say WARRENTY
Anyway, my light would shine, but my a__ was cold! Driver side only.
See yeah
The best advice to make it last longer is to use it sparingly. Not a good solution but the best one I know of.
Each time the failure seems to be identical, and even in the same location, though they kept the old parts so I can't disect them or tell exactly what happened suffice to say it burned up a portion of the circuit which caused an open and the heater function no longer works. The lights come on fine and the back segment works just fine and always has.
Any suggestions on where/how to complain to get them to fix this, and continue fixing it forever given it's obviously a design problem.
-Alan
I hate taking the car to the dealer, because even though I got the extended warranty, they still charge me $200 every time I take the car in for service. I eventually will take it in before my warranty is over, but for now, it doesn't bother me.
The dealer told me that the elements are burnt out so I've been toying with the idea of taking the seat cover off myself and rerun the elements with new wiring. I've also looked at aftermarket seat heaters but then I would have new switches mounted somewhere for them as you would not be able to use the stock switches. In any case seems to be a lot of work.
Not worth to fix it for me since it will be all out of pocket expense unless there is a factory recall on them..... good luck on that!
