OEM wires
for some reason, my Magnacore wires didn't really give me a tight fit and I had a few issues with loose connections.
any body have a use set in good condition?
or have the part number ?
it took me about 30 mins to take everything apart (air boxes and plug wiring boxes) and remove and replace the magnacors with the OEM wires Erick sent me.
Erick, we I had one casualty in my battle to get him to let go of the engine
I must say.. that the magnacors in my case, were very easily to remove.
The OEM are much more tougher to remove once they snap on tightl
the verdict:
as I anticipated, I was not getting the right connection from a few of the wires and the car was not performing to optimum specs.
The start up is much smoother, no more slight shaking at a stop light and the response has improved. The rpm pick up is a bit more even now. Before it was like On/Off switch.
before going back to the OEM cables, I would manually adjust my magnacors on a weekly basis, to ensure a few cables were making good contact.
I probably did not install the magnacors correctly and they were not the right solution for me.
http://www2.partstrain.com/v5/produc...294967266+5825
Beru Ignition Wire Set $196.99
Bremi Ignition Wire Set $197.99
http://www.mercedes-benz-parts-direct.com/epc-items.asp
MBZ078554
Karlyn/STI wire set $161.81
