Fuel Economy
Basically i'm a Brit and currently the price of fuel here is around £103.9 per litre - which is a lot...
Anyhoo
For journeys trundling back and forth to work which is the more ecomical setting W or S? Also does it make a difference...
And secondly,
Are there any aftermarket parts which one can fit to a car that will actually increase mpg?
I had something called an ecotec on an old 328i which tbh I'm not sure worked as it was always on the car, but I did *feel* better for knowing it was there :-)
Opinions on this topic would be greatly received and I'm sure all of us wouldn't mind extra mpg??
Thanks and regards to fellow C AMGers!!
And again techinically is then W mode and starting off in second worse for the mpg - I can think of arguments on both sides tbh
Thanks!
For some reason, I get worst mpg in W mode than in S (assuming being equal in the throttle). Maybe it's my driving style but I think it takes the car more effort in W mode.
Chuck
the gas used in winter is oxygenated meaning ethanol is added which yeilds less BTUs (energy) per volume so car do get worse gas consumption.
in my experience the speed you drive at is very important - i get about 26-27 mpg at 55 mph, dropping to 21-22 at 70. drag increases disproportionately with increasing speed i forget if it exponentially or logaritmically.
now my car is fully modded but i don't think this affects mileage once you stay out of supercharger activation. (no lead foot).
my sl55 intake and plugs help my gas mileage a bit......plusg- don't laff i use splitfire platiniums. they work great, i've used them for years in lots of cars. i like the electrode design i think it physically allows more spark kernel.
heavy large diameter rims will hurt mileage as would wide tires.
how about you guys check see what you're getting- level road and different speeds? i use the odo reset i assume it's fairly accurate.
I need to change my plugs to see how the car behaves.
A new fuel filter might also improve your MPGs.
Chuck
See yeah
PS: Back in the 80's I use to add 1 gallon of ethanol to 10 gallons of premium for the race car, again CHEAP octane booster. 10% is about all the higher you want to go with on the street, before water problems/corrosion/and lean outs will occur.
Chuck
maybe it is the feul but then again I was rushing 70+ coming home
Chuck
See yeah
In my C55, the best fuel economy happens in C mode, mainly because the car short shifts automatically to keep the rpm's down (which means using less fuel). But the most important factor really is driving without a lead foot. There is so much low rpm torque in our cars that I rarely have to rev above 2500 rpm's to move around in the city and keep up with the general flow of traffic. Try that, and I guarantee your fuel consumption will improve.
fuel consumption gets better and better slower you go but heck i cant drive 45 mph.
yeah the monolites are good.
now the c32 will never be an economy car but compared to the c63 or m3 we will get better consumption. just have to stay out of s/c engagement. ell,
Also some good points by all - and I know we don't drive economical cars, kinda an either or thing - but it's good to know we have quite some performance there when we want it!!!
Have any of you guys noticed when you turn off the engine the fuel needle is at wherever on the scale and then after a while you get back in the car and start it up the fuel needle is quite a bit lower???
Or is my car hemorrhaging petrol?
I've checked under the car when I reverse and can't see much but it's raining all the time here at this time of the year so is hard to tell properly?
Thanks!!!
Thanks!!!
pre-sprintbooster: city ~17
post-sprintbooster: city ~16
SB w/ pulley: city ~ 14.5
like i said, my foot = lead
damm thats good im lucky if i get 15 mpg and im stock but i drive it like i stole it.
