C32 Amg Straight Pipes Video
running just mid muffler without rear box might be an intermediate step.
i like the sound tho.
It's not that much louder when driving normal and from the back it's still looks like I have dual tip stock muffler so cops don't be bothering except when u punch the gas
844203 Centre exhaust
844212 Y-connecting pipe.
Back pressure is a bad thing. I wrote a whole diatribe about this via another post, so I won't go much into it again, however, I assure you he does not need "back pressure" on his forced induction setup.
Remember, an engine is nothing more than a big air pump, and the goal is to get as much air into it, and out of it, as quickly and efficiently as possible.
When you have a supercharger trying to push air through the engine, the last thing you want is "back pressure", ie a bottleneck in the exhaust system that prevents that air from flowing freely and escaping as rapidly as possible.
I don't know how restrictive the resonator and muffler is on the C32, however by removing it on the C55 it only gained 2 rwhp on the dyno through the normal power curve. But, it did carry the curve a little further before dropping off, therefore showing as more air is trying to escape the system, it picks up power and carries that power a little further by removing the restrictive devices. By default it should make even more of a difference on a supercharged application.
i think the quad exhaust will look good but try it out and get it dyno'd and see where the numbers stand.
I am not sure about that, it sound more like a V8
http://youtube.com/watch?v=YrKYEvd9Xvg&feature=related
