A turning point in Mercedes tuning...Performance Supercharger Pulley
Old Mar 11, 2008 | 02:18 AM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
This is the moment everyone has been waiting for. As some have referred to it, a turning point in Mercedes power. Finally, the easiest, and most logical way to make power on our supercharged vehicle. Code3 Performance proudly presents, the C32/SRT6 Performance Supercharger Pulley.
This is not the first prototype with many questions still to be answered. In fact, we have been running this pulley for months. We have 100s of hours of road testing (5000 miles and counting), 25+ dynos, and countless hours of tweaking. The pulley has also been tested on other member cars (testimonials below). The pulley has gone into production already, and will be available within the next 10 days. The basics of the piece.
- 10-15 minute install
- no new belt needed
- no additional pulleys needed
- no ECU tuning needed
- pulley comes with new bearing and snap ring pre-installed, plus extra spacers
- Both written and video instructions by our Master Mercedes Tech
- colors will be available
- Price will be $600
The graphs below are dumped from the dyno CSV data. Blue is the stock run, red is the pulley run. Below that is the A/F from the pulley run. Dynos are performed on a "Superflow 840 Dual Eddy Current & MoTec Wideband AutoDyn Chassis Dyno". Before and After dynos are performed with the car still strapped to the dyno. Dyno run is in 4th gear to 140mph with car in dyno mode. Runs are on 91 octane!
The pulley run also had our new intake mod. It picked up 4-7hp across the entire power band on a stock car. I will post separately about it, as it will be available shortly as well. It will be priced around 1/3 the cost of current intake solutions, and your system still looks stock Plus it sounds awesome! People will definitely know something is lurking under the hood.
Here are two quick testimonials from some pulley beta testers.
TopGun32 says:
"No belt slip, clutch engagement is as stock and boost comes sooner. I have had the Evosport set up on my car, and I can tell you this mod makes as much power and much smoother power delivery from around 3k to 5.5k (s/c power band). We tested last Saturday and made a handful of pulls from 40 to 100 and not once did I experience a lack of power (belt slip) while in the power band) I do suggest adding a FMIC to this set up... more boost, higher IAT's. Ease of install.. pretty much a few screws and need to let the kompressor clutch cool down."
Dan from Crossfire Forums:
"I tested his pulley on my car and as I said to me it felt, power wise, much smoother and I can only compare it to 400 hp V8 feeling since I have had those! I've driven my unmodded SRT6 for 7,000 miles, this is the first time it felt so very smooth as my 6 liter V12 Jag ! The power range came on quicker and with less effort."
As expected, there will be a lot of questions. MB owners have been told for years that the "magical SC pulley" shouldn't be touched, and that it was not possible to modify it without running into many problems... The simple fact is, you would be hard pressed to find another supercharged vehicle that creates power with a crank pulley upgrade versus an sc pulley upgrade. This is the way it should have been done in the first place. I am sure my opinion on why it wasn't will come out during the course of the thread
Here is some quick video footage.
http://www.code3performance.com/C32/c32_pulley.wmv
Peaks - 328.4/328.9
Largest power curve differential - 33.9rwhp and 40.7rwtq
Old Mar 11, 2008 | 03:38 AM
cnchung's Avatar
C32
Great breakthrough!
I ordered the LET 185 which makes the supercharger runs at almost max rpms. I think there is less room for me to order your S/C.
Just one question, replacing a larger crank pulley or a smaller
S/C pulley has the same effect of driving the S/C faster. What are the pros and cons for both solutions???
I am very interested in your intake mod, look forward to it.
The car in the vid sounds like music to me...............
Great work!!
Old Mar 11, 2008 | 05:27 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
wow definately a good return on performance for the money.
Old Mar 11, 2008 | 07:44 AM
AMGV6K's Avatar
C32 AMG
wow, imagine combining LET's 185mm + code3's smaller s/c pulley... hear that kompressor running ~ 25000rpm+
Old Mar 11, 2008 | 08:16 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Can you say KABOOM!!
Although it would be VERY interesting to watch my friend
See yeah
Old Mar 11, 2008 | 08:41 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
See yeah
maybe, maybe not my friend... allegedly some SRT-6 guys are running a 192mm crank pulley w/o problems, from what Jerry tells me. Someone'd have to "do the math" to figure out S/C speeds if someone were to add the Code3 part on top of an already crank-pulley-boosted m112k. For example, if someone had an ASP pulley, could they add Code3's S/C pulley without pushing the kompressor too far? It'd be interesting to know, for sure
Old Mar 11, 2008 | 08:51 AM
c32AMG-DTM's Avatar
Why keep us in suspense? Why didn't any tuners (Brabus, Renntech, evosport, et. al.) take the "smaller S/C pulley" approach?
I'm interested to hear what you think... personally, I doubt it was profit or cost related... I imagine if Renntech had engineered a smaller S/C pulley and ECU tune to go with it, they'd have charged at least $3k for the kit anyway, and people would've paid it.
Old Mar 11, 2008 | 08:53 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
This is from Brian at the Crossfire Forum.
By my calculations: (based on the stock 74mm S/C Pulley)
Stock Crank Pulley : 74mm S/C - - Ratio = 2.0270
Engine RPM @ 6,000 - - S/C RPM = 12,405
Engine RPM @ 6,200 - - S/C RPM = 12,819 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 14,473
178mm Crank Pulley : 74mm S/C - - Ratio = 2.4054
Engine RPM @ 6,000 - - S/C RPM = 14,432
Engine RPM @ 6,200 - - S/C RPM = 14,914 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 16,838
181mm Crank Pulley : 74mm S/C - - Ratio = 2.4459
Engine RPM @ 6,000 - - S/C RPM = 14,676
Engine RPM @ 6,200 - - S/C RPM = 15,165 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 17,122
185 Crank Pulley : 74mm S/C - - Ratio = 2.5000
Engine RPM @ 6,000 - - S/C RPM = 15,000
Engine RPM @ 6,200 - - S/C RPM = 15,500 - Rev Limiter W/Tune
Engine RPM @ 7,000 - - S/C RPM = 17,500
Using a Stock Crank Pulley, the S/C pulley would need to be reduced to:
63.6mm to equal the boost of 178mm Crank Pulley running @ 6,200 Engine RPM
62.5mm to equal the boost of 181mm Crank Pulley running @ 6,200 Engine RPM
61.2mm to equal the boost of 185mm Crank Pulley running @ 6,200 Engine RPM
If 20,700 is the max S/C RPM; and to be safe we decide to stay 10% under max - that's a target of 18,630 S/C RPM - - (when at 6,200 engine RPM)
Stock Crank Pulley would need a 50.9mm S/C Pulley
178mm Crank Pulley would need a 59.2mm S/C Pulley
181mm Crank Pulley would need a 60.2mm S/C Pulley
185mm Crank Pulley would need a 61.6mm S/C Pulley
Old Mar 11, 2008 | 10:05 AM
Thanks for the math Jerry. The good news is, it looks like it will work with both. We will get on the dyno with a car this week that already has a crank pulley. This could very well be the combination we have all been looking for to keep those pesky 335i's at bay
Old Mar 11, 2008 | 11:14 AM
Fifth Ring's Avatar
C32 AMG
Sounds cool. I might be needing a little something to keep me interested in the old dog.
Old Mar 11, 2008 | 01:02 PM
TopGun32's Avatar
can' wait to have this on both of my cars...
Old Mar 11, 2008 | 01:24 PM
TopGun32's Avatar
great info!!
Old Mar 11, 2008 | 01:26 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
does anyone know the size of evosports dampned pulley?
I assume a larger HE and johnson 030 would be a must to keep high IATs at bay for folks wishing to try the double whammy.
what about fuel? will my evosport ecu adapt?
lawd have mercy........
Old Mar 11, 2008 | 06:05 PM
A larger HE us a must, whether used by itself, or in conjunction with a crank pulley.
As far as tuning, this is one of those instances when software might actually be worth doing. I am headed to the dyno tomorrow night with a crank pullied car to do some testing. A/F and MAP are the two big concerns right now. We already have a MAP solution ready to go that will extend the range, if its needed. Plus it has a built in port for running a boost gauge, so no need to tap anything
Old Mar 11, 2008 | 06:39 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
Brandon
So from around 2600 RPM to about 4000 the car is running from the mid 14's to 13's A/F Ratio? What are the stock A/F ratio from 2600 to 4000? Sorry if I am reading this incorrectly.
Basically I am just making sure the car at any RPM is no where near a dangerous A/F ratio.
If there is no tune needed and easy to install I think I may in. How many will you have and how long to get them.
What are the negative affects of this upgrade compared to a crank pulley upgrade.
This looks like a very good product I think people will be all over when all questions are asked and answered.
Old Mar 11, 2008 | 07:09 PM
mustang281man's Avatar
C32
can we get some pics of this pulley
Old Mar 11, 2008 | 08:58 PM
TemjinX2's Avatar
props for the math.
Old Mar 12, 2008 | 01:17 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
+1
Old Mar 12, 2008 | 06:12 AM
warnhammarc32uk's Avatar
Brandon,
How do I order one to be shipped to the uk? What does the flywheel gain equate to on a standard car with no ecu tune?
Last dyno run showed 288 rwhp.
Old Mar 12, 2008 | 06:32 AM
AWDman's Avatar
OK pl keep us posted. save the fuel issue my car may be a prime candidate for a double whammy. assuming IATs are controlled, no clutch slip, ok fuel....I would be 390 rwhp
one more important thing..........will the s/c engagement point be unaffected in terms of rpm or load? i don't want to give up my 24 mpg hiway.
Old Mar 12, 2008 | 08:25 AM
c32AMG-DTM's Avatar
Brandon, will the S/C pulley be available in different sizes? If not, can you share the size (mm) of the Code3 modified S/C pulley?
TIA!
Old Mar 12, 2008 | 10:37 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
very..very interesting....keep us updated
Old Mar 12, 2008 | 01:50 PM
c32used's Avatar
LET C32 2002
Brandon when you finish extensive testing on a crank pullied car with safe operating and A/F range I might consider it. Keep us posted....
Old Mar 12, 2008 | 01:57 PM
Hjartarson's Avatar
2002 C32 AMG
Gimme gimme gimme gimme !
Will this work with my MKB tuning? (Modified engine management system with readapt ignition map and injection map)
If so, I'm in!!! intake too!
Old Mar 12, 2008 | 05:14 PM
SteveL's Avatar
C43, SLK32, CLK63 Black Series
Is the A/F chart with the new pulley or the original pulley? It would have been good to post red and blue to show any differences.
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
