Yet another Kleemann post
Tell them you'll dyno the car before and after ... if they don't make 40+hp, they owe you $1200
Guys @ Brabus claimed to have a cam and ECU set-up good for 40hp & xtra rpms.
I feel the same way. if that was true IMO I would think everyone would be doing it for $1200
Also, keep in mind they may have achieved those numbers at the absolute peak level, however you will only be at that level for a split second. I'd be much more concerned about the area under the curve. What are the increases throughout the entire pull? If I'm going to pick up 33rwhp at only 6200rpms at the top of 4th gear, but no other noticeable changes down below, then it's certainly not worth it. For me, I'd make them provide actual dyno graphs that can show the gains throughout the powerband. If you're seeing the 11% gain throughout the entire curve, then it's worth something. As I've stated before, peak power doesn't mean a thing for overall performance. You want a very linear curve on the dyno, showing power across the entire rpm range, not just at the very top. This is why a car w/ 300hp from 3000-6000 rpm's will outrun another car w/ 350hp from 5800-6000 rpm's (all things being equal otherwise). I hope this is making sense the way I'm writing it. It makes sense in my head, but sometimes that doesn't translate into text...
Kleemann's website says the following:
2.6, 2.8 and 3.2 V6 & 4.3, 5.0 and 5.5 V8
The KLEEMANN normally aspirated (NA) V6/V8-engine tuning programme is available for all Mercedes-Benz models equipped with NA V6 or V8 engines. Below you will find the specifications of the KLEEMANN "Stage" tuning concept for a 5.0 litre normally aspirated Mercedes-Benz engine.
*actual power and torque output depend on a large number of variables. For detals please goto the FAQ section.
I plan on getting Eric from LET to do some dyno tuning on mine. I have access to a dyno and he is local for me, so hopefully we can do some real world testing to show the gains his and AMG Jerry's tunes will produce. I know they're testing their tune on cars in Chicago right now too.
I'm craving some extra power and like everything else I've ever owned I can't leave well enough alone. Horsepower is worse than crack...!!!
Once my hardware setup is finalized, I’d really enjoy a semi-private day at the ‘strip trying some of Erick’s and Jerry’s tunes. That would be a kick! It may not happen, but LET will be doing my tune when the time comes. Good people.
Sounds way to high imo...
its hard to squeeze out hp from an ECU flash on a regular motor.... ECU with other mods would of course bring higher gains... on a non kompressor 55, i would say, ECU, Headers would be a good start... Maybe a LSD?
On a personal note, i hate doing internals if there is no need... Cams and other things of this nature.. i would stay away from unless your die hard and looking to shave tenths off your et.
my .02
with the cam and good ecu tune. it may be doable, but not with ecu along. no magic will bring 40hp to the C55 NA V8 with just the ecu.
my .02
we have discuss this in the 32 thread on the cams. cams move hp to higher rpm and maybe an increase of 10hp at most. making the rpm higher is up to raising the redline limit on the ecu. it has nothing to do with cam. basically cam is good for people who are die-hard track fan which it is better to have the power up in the higher rpm so you don't have to gear hunt for the hp and torque. it is the same reason NSX and S2000 are so good on the track yet crappy in daily commute.
